a1671. iPad. pro
  • rbuck9
    • Nov 2012
    a1671. iPad. pro
    can anyone identify missing component above
    1610a3 ?can't find any info on this board
    sorry couldn't add photo.
  • mon2
    • 14659
    Re: a1671. iPad. pro
    Post a picture of what you are hunting for.
    At the bottom of the same box used to post your text will be a button to add an attachment.
    • GeirAndersen
      iPad .pcb file collection
      by GeirAndersen
      I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
      Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
      IPAD COLLECTION 1
      +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
      +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
      +---iPad mini3 820-00008(A1599) 820-00002(A1600)
      +---iPad mini4 820-00180(A1538) 820-00177(A1550)
      +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
      +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
      12-09-2024, 09:28 AM
    • Pasglop
      iPad A1671
      by Pasglop
      Hello I need the diagram and the boardview of the iPad A1671, following a bad manipulation on my part I lost the backlight. Thank you
      12-29-2024, 02:57 AM
    • gilad123
      iPad Pro model A2459 Identify a component
      by gilad123
      Hello
      I have an iPad Pro model A2459
      Its backlight does not work. After opening the iPad, everything looks normal except for three components that are on the back of the screen near the flexible cable. I can't find any info on them model/value?
      Does anyone know?
      05-16-2024, 11:37 PM
    • MrBojangles
      Boardview for iPad Pro 12.9" Gen2 A1671
      by MrBojangles
      Hey!
      I have a iPad that doesn't start. I tried replacing the Tristar chip and I don't know if I ripped the pad or if it went with the chip but I would really like to know where that pad leads so that I can put a jumper on it.
      I have the tristar chip next to the pads oriented as it should be if that helps any.
      03-15-2025, 09:04 AM
    • KappaDev
      iPad Pro 12.9 2nd Gen A1671 - 1mA No Power, No Charge
      by KappaDev
      I have a 2nd generation iPad Pro 12.9" Model number A1671. I don't usually work on these, but I suppose today is the day I start. Apologies for any ignorance on tablet matters. On Type-C to USB amp meter, showing 5v @ 1mA
      (0.005W) then instantly to 0mA back and forth. Power draw is the same with and without screen and with and without battery connected. Of course, not enough current for anything to show on thermal camera.
      I can't find any boardview and I'm not certain it even exists. Probing coils on top side of board reveals no voltage present...
      04-05-2023, 01:59 PM
