Help asus x442uq no power
  • anceng
    • Nov 2020
    • 21
    • Philippines
    model: asus x442uq rev.2
    issue no power after I install the battery
    when connected to power supply sometimes the current draw is .12A
    vcc core and vcc_gt missing. dgpu voltage, 3v3 and 5v is present
    i replaced PU8001, still no power.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Help asus x442uq no power
    Voltage on ram coil present??
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • megcox
      ASUS PD551LA REV2.0 not booting after one week power off
      by megcox
      Hi everybody
      My ASUS PD551LA (REV 2.0), after a week powered off with power adapter disconnected, is not booting anymore.
      If I plug the adapter, the battery is charging, the power led lights but after pressing the power button there is no sign of life.
      I've found the Boardview file of the motherboard and the schematic of PU551JA (that looks 99% compatible).
      I've disconnected the battery and all devices except screen (I removed also the RTC battery, hope it's not a problem at this stage...) and checked all signals and power rails involved in the power on s...
      10-12-2024, 03:26 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
