A1278 Random crashes 820-2530
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    I'm having a go at this Macbook pro mid 2009 laptop I've got for chips bare bones. It's a pretty interesting case...Fresh thermal paste, clean the fan, inserted HD, memory sticks, clean OS install. CPU temps 70-100C.
    Laptop seems to be working ok for a number of days. I can run benchmarks all day long, browse the internet etc. I reboot it every now and then (bear in mind, still keeping it pretty hot). At one of these times - it won't boot to OS.
    Command V shows some random kernel panics (no mention of GPU).
    HD filesystem gets corrupt - to a point where fsck cannot fix it (on another macos). While in this condition it can even crash reboot on OS installer.
    After it cools down I can reinstall the OS and the story repeats itself. Regardless whether its running off of battery or AC.
    Memtest86 can run for hours, no memory issues. As mentioned before, benchmarks can run for hours, no issues, no glitches, no reboots.
    What gives?
    Did some measurements and I am wondering if it is normal for the PPVCORE_S0 to fluctuate?
    Any idea what could be causing this strange behavior?
    PPVCORE_S0_CPU - starts at 0,994V ? full boot down to 0.90V then to 0.75V
    PPVCORE_S0_MCP - 1,005V (C7565)
    PP1V05_S0 - 1,068V
    PP1V1R1V05_S5 - 1,061V
    PPBUS_G3H_CPU_ISNS - 12,57V
    PP1V05_S0 - 1,068V
    PP1V5_S0 - 1,492V
    PP3V42_G3H - 3,40V - resistance to ground (black lead) - 53,3k (C4650)
    PPVIN_S5_IMVP6_VIN - 12,58V
    PPV5_S0 - 5,01V
  • mon2
    • 14668
    Re: A1278 Random crashes 820-2530
    Hi. Yes, believe that the logic boards we have repaired are with the same fault as yours. The latest one, the client was complaining that she could barely touch the enclosure of the macbook from too much heat. She felt it would catch fire and stored it in her bathtub (without water of course) for safety.
    After the referenced tantalum cap - cool as a whistle and no more flaky results / random crashes. See more for details.
    https://store.rossmanngroup.com/d3-c...0-1-piece.html
    Review this video - we have repaired a few of these logic boards by using the recommended larger size tantalum cap:
    https://youtu.be/NfY6vTQthiE
    For future readers, we used the following part from Arrow with success:
    EEFGX0E331R PANASONIC
    Cap Aluminum Polymer 330uF 2.5VDC 20% (7.3 X 4.3)
    Update: Here is a great replacement for this defective cap (in stock @ Arrow):
    https://www.arrow.com/en/products/ee...31r6/panasonic
    rated @ 7500mA
    • cruiser_
      • Nov 2019
      • 124
      • Ireland
      hi @mon2,
      I read about this issue and watched Louises (and others) video too. Thought this was an issue on slightly newer boards though?
      "C7771 is a tantalum cap that you read 0.331v on instead of 1.05v on, this might help you. Most of the time, it is a bad capacitor. It is too small and the single small tantalum cap is not fit for this circuit, it dies, and causes machine to not turn on when it gets cold. You can confirm this cap is bad with a small bit of heat - it will work again until it cools down."
      It seems in my case things work grand when cold and I am getting a steady 1.05V there?
      • piernov
        • Jan 2016
        • 4439
        • France
        A1278 != A1286
        https://logi.wiki/index.php/A1286/A1297_Common_Issues
        HDD & HDD cable replaced?
        • cruiser_
          • Nov 2019
          • 124
          • Ireland
          hi piernov. Different HDD/SSD tried and yes, the cable was replaced according to previous owner.
          What's puzzling me is that it happens over such a long period of time. Perhaps some idea what to 'stress' more?
          I am thinking some massive disk benchmarks running over and over again - but I am not aware of one that would actually verify what's being read back from disk is what had been written to it.
          • cruiser_
            • Nov 2019
            • 124
            • Ireland
            hmm... I disconnected the disk and DVD drive, now I'm in a state where the OS installer boots, keeps loading and restarts at 'examining volumes' or earlier. suffice to say when it cools down, things normalize.
            is it 'normal' for the board itself to get to a 50/60 degrees Celsius mark?
            • mon2
              • 14668
              To me, it sounds high. The heatsink is mounted properly ? Are you using thermal paste or thermal pads under the heatsink ? We have used the T-Global brad of thermal pads - bought from Digikey. We met T-Global (Taiwan) at past trade fairs in Hong Kong and they claimed to be the leaders in the field. A bit more cost but we are pleased with the results on reworking iMAC cards and CPUs with their products.
              • macattack600
                • Aug 2011
                • 97
                Memtest is not all that great I've used it and still had to swap memory try once more seating 1 at time and different sticks too.
                Does the MCP feel burning hot? The installer loading over and over really does not sound good.
                Run ASD and see what that says
                • cruiser_
                  • Nov 2019
                  • 124
                  • Ireland
                  @mon2 i replaced the paste on MCP & CPU with arctic cooling one, also cleaned the vents etc.
                  @macattack600 - great suggestion, that's exactly what I have started doing since yesterday. I have been testing it with just one stick in.
                  Installed BigSur with opencore, now running f3 read/f3 write and memtester at the same time repeatedly, so far so good with just one stick in.
                  Cannot run ASD (don't know how to get there with opencore patched OS...'D' makes no difference in the boot process). Is there another way of opening it?t
                  I've been using memtest86 successfuly on PCs and it never failed me in finding bad RAM. Is this different on MACs?
                  • cruiser_
                    • Nov 2019
                    • 124
                    • Ireland
                    A quick update.. after a few weeks of stable operation with one stick, today the macbook did not reboot (repeatable kernel panic).
                    Booting off memtest86 gets stuck at 'getting memory size' or does not show anything at all. tried two memory sticks at this point with little difference. disk and dvd disconnected.
                    I've gone through the vcore voltages, MCP voltages, SATA voltages etc. all look nice and steady.
                    What gives? :\
                    • EvazX
                      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                      by EvazX
                      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                      However, after some time, the replacement motherboard...
                      08-25-2025, 06:09 PM
                    • pcbmaniac
                      MacBook A1278 (3115) No PPBUS_G3H Issue
                      by pcbmaniac
                      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                      1. U7000 Measurements:
                        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                      2. Resistors:
                        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                      • If I also decide to replace the SMC, do I need to order it pre-programmed,
                      12-02-2024, 04:12 PM
                    • Prosatanosz
                      Asus B85M-GAMER no hdmi output and random restarts
                      by Prosatanosz
                      Hi!
                      Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                      10-19-2024, 05:27 AM
                    • Dreigas
                      Asus TUF Gaming FX506LX laptop just stuck at random time
                      by Dreigas
                      I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areas—about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
                      One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
                      07-27-2024, 05:58 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
