Asus Eee Slate B121
  • CMC007
    • Apr 2014
    Asus Eee Slate B121
    Hi Gus I have a will not start on battery But if started on mains power will run on battery any ideas where to look Thanks Carl
  • mon2
    • 14662
    Re: Asus Eee Slate B121
    How old is the battery? # of charge cycles?
    Does the battery charge with the adapter?
    If in doubt, test with a known good battery.
    • CMC007
      • Apr 2014
      Hi mon2 thanks for the reply The battery is new eg about 4 weeks it is charging The device turns on when connected to charger but not on battery When running it will continue when charger is removed I just do not know where to look for the fault Thanks Again Carl
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
      • rob777
        Asus TUF won’t run off battery
        by rob777
        I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
        I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
        Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
        Thanks....
        05-27-2025, 07:07 PM
      • Iherduleikgemz
        Asus FX505DY - Battery not charging - BQ24780S
        by Iherduleikgemz
        Hello everyone
        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
        01-13-2025, 03:54 PM
