Possible cause of coils no voltage after SIO swap because 19 V on middle pin Lenovo
  • pischu7
    • Mar 2022
    Hey guys,
    I am reading in here for years but have my own first questions just now. Thanks a lot for all the support so far!
    So here we go: Due to sheer stupidity I connected 19 Volts to the middle Pin on a Lenovo Laptop (Board NM-A361) and fried my SIO instantly. I know that because I had some smoke and a visual damage on the chip. So I bought a already to my board programmed replacement and soldert it in.
    However its not working just jet. I do have 19 V on all of the first Mosfet´s on the board but nothing at the coils. I do assume that the Super I/O is working since I do have a power-on LED when I press the Powerbutton and it goes out again on longpress; the power consumption is around 11 mA. The board is also charging the battery.
    I was under the impression that the Super I/O is starting up the different voltages on the board. So the obvious question is: Why not?
    Does anyone have a idea what I could check to investigate further?
    Thanks a lot in advance
    Markus
  • Salvador Pérez
    Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
    by Salvador Pérez
    Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
    • 0.91V for the GPU
    • 1.7V for VRAM
    • 3.3V and 5V rails 1.8V for the BIOS
    • 0.9V for the CPU and iGPU 1.2V for the RAM
    However, these two coils are not showing any voltage....
    03-10-2025, 11:50 AM
  • valvashon
    Repair Success! Middle Atlantic UPS2200R-IP
    by valvashon
    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
    02-06-2024, 12:54 PM
  • Adogabriel100
    iPhone 14 PRO CPU SWAP
    by Adogabriel100
    Hey!
    i have a quik question:
    im having a iphone 14 pro. trying to make a CPU swap but i just have a EU Donnor Board (With sim card) and the original board is USA Board (E-SIM) . is there any problem with the baseband activation bettewen them?
    i already made the swap but not getting IMEI (BASEBAND) and unfortunately don't have iSocket to test it first. Thanks
    10-16-2024, 11:41 AM
  • coni
    Asus UX501J - EC (IT8585VG) burnt by broken charging port middle pin
    by coni
    Hello.
    I'm trying to repair an ASUS ZenBook Pro UX501J and I need a little help. The story is like this:
    The charging port broke and +19v touched the middle pin, therefore the super IO chip now has a hole in the middle (so obviously I will replace it, it is IT8585VG), but there is also a nearby resistor burnt and I don't know it's original value. Here is a picture attached with the resistor (the one circled with red), anyone knows how can I track down its value? It seems to be connected between the middle pin and ground, so its value is important, I think.
    Thank you....
    04-07-2023, 02:26 PM
  • liquidzorch
    Could HP middle pin cause damage to SOC?
    by liquidzorch
    Hello. I am about to get my new motherboard for a damaged starwars edition HP laptop (15 an001). The original motherboad got a short on 3.5v line, I traced it to the SOC (processor) and with the price of a new reballed i5 processor, it was better to just buy another board.
    I still don't know why it would fail all of a sudden, I had just paced it down, I was watching a video, it kept playing then a second after I placed it down it shut off.
    Now I am wondering if I should buy a new power supply, maybe there is a short between the middle pin and 19v line that occured...
    02-10-2023, 07:41 PM
