ACER Spin SP113-31-P6NZ not working on Battery
  • mon2
    • Dec 2019
    • 14191
    Re: ACER Spin SP113-31-P6NZ not working on Battery
    There has to be a local resistor on the pin # 5 trace or perhaps is missing due to a drop of the unit ?
    This local pull-up resistor will then go to an always ON rail that must be powered from your battery supply. Assuming the battery is charged, the open drain ACOK# line should float to the ALWAYS ON rail value.
    If the adapter is mated, this ACOK# should be LOW (0v).
    • mferna14
      • Jun 2018
      • 1020
      I wish I had the Schematics, but this track has NO resistors at all. There is tiny track on Pin 5 & then come the on-board hole which directly leads to Pin 110 of the IO Chip. If I can get a clear photos, will surely upload it.
      • mon2
        • Dec 2019
        • 14191
        With the power removed - what is the resistance to ground of the pin # 5 of this device ?
        I would think that this pin is an open-drain output, like all past charger ICs from TI. So it will need a pull-up resistor.
        Maybe they have an internal pull-up ?
        • mferna14
          • Jun 2018
          • 1020
          143Kohm (pin 5 for BQ24737 to GND of the motherboard, here you go... I think we have got the answer.... I will check if I can purchase the schematics for this model.
          • mferna14
            • Jun 2018
            • 1020
            Just got the schematics for this ACER Spin SP113-31-P6NZ model Wistron IRONHIDE_APL - 16835-1M - 16A08-1M Schematic... Hope it helps all.
            • mon2
              • Dec 2019
              • 14191
              Schematic shows a 100k pull-up @ PR4427 on pin # 5 - do you have the same on your board ?
              What is the voltage of 3D3V_AUX_S5 ?
              • mferna14
                • Jun 2018
                • 1020
                3D3V_AUX_S5 is 3.27V & I do not see the 100K PR4427 pull resistor... REG on this pin 16 should be 6V, where as it's 0 volts, but before the DIODE PD4401 on the "K" point the volts keeps on dropping & no PWR_CHG_REGN, this should be around 3.3v, only 1 volt on Pin 11 of BQ737
                • mferna14
                  • Jun 2018
                  • 1020
                  I soldered a defective BQ24737 taken out from a donor board. I soldered a good one & get all voltages on the point where I was have problem. But the problem still is there, the motherboard detects the battery but does not charge at all. When the motherboard is on, I plug in the battery, after a few seconds the LED glows orange & then turns off but the motherboard is still working, & as soon as I remove the AC power, it just turns off. Pin 11 of BQ737 is still giving out 0.72 volts where as I think this should always be 3.3v???
                  • mon2
                    • Dec 2019
                    • 14191
                    Check the SRN and SRP voltages at the charger IC pins.
                    Post their values.
                    • mferna14
                      • Jun 2018
                      • 1020
                      JUst entered the WS.... Pin 12 SRN 2.7V and Pin 13 SRP 2.7V when ONLY on AC Power, no battery attached. As soon as I plug in the battery terminal with AC power attached, the voltages on these point goes to 12.6V & then drops to 0.78V. & one more thing as soon as I attach the battery terminal the motherboard turns ON (BLUE LED) by itself.
                      • mon2
                        • Dec 2019
                        • 14191
                        Remove all power. Check the mosfet resistance for each device.
                        Meter in 2k scale.
                        source (1-2-3) & drain (5-6-7-8)
                        source (1-2-3) & gate (4)
                        gate(4) & drain (5-6-7-8)
                        Post the readings for each mosfet.
                        Time for a run to Freshco...BBL.
                          • 20888
                          Have you checked the battery switch SW1
                          • mferna14
                            • Jun 2018
                            • 1020
                            The Battery RESET switch is 100% fine.
                            PU4409 (GND to these point)
                            source (1-2-3) & drain (5-6-7-8) = 1M
                            source (1-2-3) & gate (4) = 125Kohms
                            gate(4) & drain (5-6-7-8) = 1.2M
                            PU4403
                            source (1-2-3) & gate (4) = 130Kohms
                            Drain MOSFET even seems to be ok.. I removed it & checked
                            • mon2
                              • Dec 2019
                              • 14191
                              Can you confirm that you are testing the mosfets as follows ?
                              Red meter probe on source & black meter probe on drain ?
                              and so on...
                              for each mosfet. These tests are not to ground. Repeat for each mosfet linked to the charger IC.
                              • mferna14
                                • Jun 2018
                                • 1020
                                The MOSFET were test NOT with GND, but with meter leads & none were shorted, even I removed them & tested them, they are ok. But the DRAIN Mosfet PNP PU4408 ( Souce & Gate both should be high). As per the circuit the Gate is directly connected to 19V_AD+ which is right but why am I getting 2.7V on Drain, should this NOT be Zero??
                                • mferna14
                                  • Jun 2018
                                  • 1020
                                  One more thing I noticed, I tested the voltages on the battery terminal, when the battery is installed, I put in the AC Power & surely I get the required charging voltage nearly around 16V on the battery + terminal & even checked the Voltage & frequency on both sides of the boost caps, they last for almost 10 sec & then start turns down.
