X453ma rev 2.0 no display
+ More Options
Posts
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Board taking 115mA
    I already Flashed the bios same issue
    PM_PWROK_SOC- 3.2V
    ME-SUSPWRDNACK- 0V
    AC_IN_OC# 0V
    PM_PWROK 3.2V
    +1.0VSUS0 1.V
    PM_SUSC# 3.1V
    PM_SUSB# 3.1V
    CORE_PWRGD 2.9V
    +3VA_EC 3.3V
    EC_RST# 3.2V
    PLT_RST# 3.2V
    5VSUS_ON 3.3V maybe this is the issue?
    3VSUS_ON 3.3V
    ME_ACPRESENT_SOC 1.5V also this?
    +1.5vs_PWRGD 2.7V also this is not normal?
    ALL_SYSTEM_PWRGD 3.2V
    PM_RSMRST# 3.3V
    +1.05VS_PWRGD 3.3V
    Hope someone can help me on how to solve this type of issues\\
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: X453ma rev 2.0 no display
    Measure all the rails as per sequence on Pg3 of Repair guide. Check Powergood signals one by one. Since board is taking 115mA, most of the rails are likely to be present as this mb posts at about 140-160mA but should go upto 220-240mA during post.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      measure all the rails as per sequence on pg3 of repair guide. Check powergood signals one by one. Since board is taking 115ma, most of the rails are likely to be present as this mb posts at about 140-160ma but should go upto 220-240ma during post.
      +1.5vs_pwrgd-2.7v
      +1.05vs_pwrgd-3.3v
      1.0vsus_pwrgd-3.2v
      all_system_pwrgd-3.2v
      core_pwrgd-2.9v
      ddr_core_pwrok-1.3v
      ddr_pwrgd-3.2v
      ddr_pwrgd_soc-1.3v
      dramrst_ec- 0v
      rtc_rst#- 3.1v
      vram_pwrgd-3.2v
      sus_on_dsg-0v
      sus_pwrgd-3.2v
      susb_ec#3.2v
      susb_ec_dsg-0v
      susc_ec#-3.2v
      susc_ec_dsg-0v
      +5va - 5v
      +3va - 3.3v
      +3v_dsg-3.2v
      +3va_ec-3.3v
      ec_rst#-3.2v
      +12vsus - 12.8v
      +3vsus-3.3v
      +5vsus-5v
      pm_pwrok-3.2v
      pm_rsmrst#-3.3v
      +1.05vs-1v
      +vcore-0.9v
      me_ac_present_soc-1.5v
      me_suspwrdnack-0v
      me_suspwrdnack_ec-0v
      pm_pwrbtn#-3.3v
      pm_pwrok_soc-3.2v
      pm_rsmrst#-3.3v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        R9110-voltage on both sides??
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          pR9110 12.7v on both sides
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            This is perfect. MO_DRAMRST# Present?? Consumption on dc supply 01 With ram 02.Without ram??
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              SL1901 no voltage raeading
              with ram and without ram equal 110 amps
              the ram is already tested to other unit and perfectly fine
              • jxrepman
                Asus X453MA won't turn on and green led light blinking
                by jxrepman
                Hi there,
                I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                I have checked the charger and it is giving 19+ V
                I have disconnected the battery and pressed power button for 30 seconds.
                I tried another RAM stick.
                Tried disconnecting the keyboard and touchpad.
                Tried disconnecting the HDD and the wifi adapter.
                The problem persists.
                Hope you could help me out on this one. Thank you.
                12-14-2024, 06:40 AM
              • Christian0734
                Asus X453MA Rev 2.0 Backlight and fan
                by Christian0734
                I brought an Asus X453MA into the workshop, its owner tells me that it doesn't work on battery despite having replaced it with a new one and that it's making noise. I diagnose and find, firstly, that the fan is constantly running at full speed. Secondly, that the computer works on battery but there's no backlight when the charger is not connected. I look at the screen connector because I see that the adhesive is not holding. I observe that there probably was a short circuit. I isolated everything with hot glue and reassembled it, I don't think it needs to be replaced. The BIOS is...
                11-23-2023, 08:32 AM
              • julianmustofa
                Asus x453ma only turn on when plugged in (battery was fine)
                by julianmustofa
                Hi all
                Iv'e been working on asus x453ma that only turn on when the ac adapter connected
                The battery itself was fine
                So this is what happen
                -plugged ac adapter
                -trigger power button
                -laptop turning on
                -unplug the ac adapter
                Laptop still on with battery
                -without ac adapter
                And nothing happens
                Have no idea what is going on
                Charging sistem still works when laptop is turning on
                And also when battery reach 100% the charging indicator still red. It should turn white/green...
                10-18-2023, 01:48 PM
              • Yosua
                ASUS X453MA REV 2.0 +3VS didn't work
                by Yosua
                hi friends, I want to ask for help to solve my new problem on this ASUS X453MA REV 2.0 mobo, when I connect the charger the power light can turn on but the charging light is not on (battery condition is not installed) and the current shows remains at 0v, I've done flash bios but the case persists, and I've checked on all coils everything is okay, including the vcc coil, and after I search on the 3v&5v block alw it turns out +3VS doesn't show up it only shows 0.110mV in pq9108 on board view.
                and my question is, where does this +3VS voltage come from?
                I...
                06-14-2022, 08:53 PM
              • Yosua
                Asus x453ma not charging
                by Yosua
                hello friends, I hope someone will give up a moment to help me solve the problem on the asu x453ma motherboard with the condition that it can't charge when it is charged, and this is the result of measuring the bq735 ic voltage
                acin : 19v (pin1)
                acdrv: 4.02v (pin4) unstable
                sda: 2.5v(pin8)
                regn: 6.2v(pin16)
                vcc: 19v(pin20)
                I hope someone can help me or give directions to solve this problem, thanks.
                11-07-2021, 08:30 PM
