La-d713p uma
  • sakalaz
    • Sep 2019
    • 31
    • Lithuania
    La-d713p uma
    I have a board LA-D713P with Radeon GPU. I suspect it has a faulty GPU therefore would like to convert it to UMA. Has anyone tried to do it?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: La-d713p uma
    Just lift the graphics power coil.
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • AJ847.63e
      HP Pavilion X360 14-dh1084tu Suspect faulty SIO
      by AJ847.63e
      I've got a mainboard FAROE DIS X32 MB MV 18742-1 0GG03.0011.
      Original state was I was getting 3v on the power button. Went through the schematic power sequence and we seem to be getting stuck at point -4. The outputs from the SIO 5V_S5_EN and S5_EN are missing, and the inputs for PU4551 seem wrong. 1.36V and 9.6V for En1 and EN2 respectively. At first I was getting 3.34V on EN1 but it's seemed to have dropped. PWR_5V_FB is 0.6V.
      Checked all around the board can't see any shorts, except around the dimm slots and CPU so I'm assuming that's normal. 180...
      08-06-2024, 11:52 PM
      HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
      This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
      09-06-2024, 11:17 AM
    • JarzabekPZ
      HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
      by JarzabekPZ
      I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
      08-08-2025, 03:40 AM
    • Spudgun
      Why doesn't current just bypass faulty capacitors.
      by Spudgun
      Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
      04-01-2025, 10:33 AM
