MacBook Pro aA1398 no brightness control on Big Sur
  • ACS-Repair
    • Feb 2021
    • 204
    I having an issue where in Big Sur, the screen brightness doesn't work on the F2/F3 keys or in the display preferences of my mid 2014 A1398. If I boot from a High Sierra flash drive, it works fine. I've seen others commenting on this on the internet as well. It seems that if you have Big Sur 11.2.3 or lower it works. Anything higher there is no control.
    It seems like the display panel itself may have been dropped from Apple's support list. While the part number appears to be valid, I don't have a history on this computer. Just curious if anyone else has come across this.
  • kjchatman
    macbook pro 2011 dgpu disable brightness control
    by kjchatman
    there is an instructional on youtube that is in a foreign language and the gmux is reprogrammed to disable the dgpu. then he wires it to restore brightness control. a wire wasn't ran from the pch but a wire was used to restore the brightness control. Can anyone tell me how to wire the board the way it is done in the instructional?
    https://www.youtube.com/watch?v=XqTBSakHNdg&t=3s
    03-24-2022, 01:36 PM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • ohren
    Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
    by ohren
    I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
    The setup is basically:
    Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
    Transistor is switching the 3.5 V supply on the power board....
    12-05-2024, 11:10 AM
  • Flasman90
    Macbook Pro DFU Restore Issues
    by Flasman90
    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
    08-30-2025, 10:27 AM
  • Featurea
    Macbook air a1932 bootlooping after airport control
    by Featurea
    once again I am here with problems with my macbook. After successful repair, when everything was working fine, I took my macbook air to the airport and flight with it in carry-on baggage. Firstly after landing it was working fine, but suddenly it shuted down and started bootlooping to the apple sign. I managed to run it normally throught SMC reset, but problem was going back untill SMC reset stopped working. Now Macbook is bootlooping in normal start, I can't go to recovery, I tried internet recovery, but after fully loaded download bar it switches off.
    I have...
    06-21-2022, 02:20 PM
