MBA A1466 2017 820-00165 Green ok, no power FAN not spinning
  • Electron67
    • Oct 2021
    • 8
    • France
    Since a couple a days, i try to fix 820-00165 Mobo, without success for the moment.
    Measures :
    1. PVRTC_G3H = 3.33v
    2. RTC_RESET_L = 3.3v
    3. PCH_SRTCRST_L = 3.3v
    4. PCH_INTVRMEN = 2.58v
    4.1 PCH_INTRUDER_L = 2.50v
    5. PCH_DSWVRMEN = 2.50v
    6. SYSCLK_CLK32K_RTCX1 = 0.44v
    7. PP3V3_S5 = 3.3v
    7.1 PP1V8_S3 = 0v (EN pin 0v)
    8. PM_DSW_PWRGD = 3.4v
    9. PP3V3_SUS = 3.3v
    10. PM_BATLOW_L = 0.035v (3.3v battery pluged but still no power)
    11. PM_RSMRST_L = 3.04v
    12. PM_PWRBTN_L = 3.4v ; SMC_ADAPTER_EN = 3.4v
    PM_SLP_S4_L = 0v
    Current condition :
    SMC & U7100 both changed
    U1900 changed
    Q3000 changed (one leg discovered broken during desoldering).
    I'm a the end of "what to do more"... any idea ? Thanks.
  • mon2
    • 14667
    Re: MBA A1466 2017 820-00165 Green ok, no power FAN not spinning
    Voltage value of PPBUS_G3H ?
    • Electron67
      • Oct 2021
      • 8
      • France
      Hi mon2,
      Thanks for reply.
      PPBUS_G3H = 8.5v
      • reformatt
        • Feb 2020
        • 1501
        History of the board? Any liquid damage? PM_SLP_S4 issues if everything measure ok are usually corrosion related (open tracks etc).
        Check to see if the any of the S4 and above voltages pulse once or twice. Also check impedance on the coils, especially L7630. Anything under 150 ohms in my experience on that coil is a waste of time (damaged PCH).
        • Electron67
          • Oct 2021
          • 8
          • France
          Board is in a very good condition, no liquid damage or corrosion.
          PM_SLP_S4_L=0v but the lane is not grounded.
          R measurement after L7630 gives ~218Ohms (0.217v in diode mode).
          A precision i previously forget to mention : When i connect the battery, PM_BATLOW_L goes up to 3.3V but PM_SLP_S4 remains to 0v.
          • Simplebeans
            • Sep 2021
            • 135
            Your PM_BATLOW_L voltage is ok.
            Generally speaking (minus other board issues such as liquid damage etc) If the battery voltage is NOT low or no battery is connected the SMC will send the 3.3V signal.
            The other thing that can effect that signal is if you don't have a geniune mac power adapter connected.
            Have you checked U1950, what are you getting at PINS #2 and #8?
            • Electron67
              • Oct 2021
              • 8
              • France
              Power adapter is a geniune one.
              On U1950 => Pin2=0.074v; Pin8=3.42v
              • Simplebeans
                • Sep 2021
                • 135
                Yes your PM_BATLOW_L is fine.
                Ok and voltage measurement at PIN #1? Are you measuring directly at each PIN or on a capacitor/resister thats on the lines?
                • Electron67
                  • Oct 2021
                  • 8
                  • France
                  Ok, thanks.
                  Pin2 : 0.128v on U1950 pad, 0.086v on R1950;
                  Pin8 : 3.4v on U1950 pad; same on C1950;
                  Pin1 : 0v on pad & R8166.
                  • Simplebeans
                    • Sep 2021
                    • 135
                    Ok, thanks.
                    Thanks do you see PIN #1 pulsing at all when you measure the voltage? Try and plug in the charger and when you do make sure you are watching your multimeter to see if anything happens?
                    Also can you measure the voltage at resister R8162 PIN #1 and #2 as well.
                    • ugamazing
                      • Jun 2013
                      • 171
                      • usa
                      Check your S5/S3 rails in multiple spots on these 2017 00165 boards just to be safe. We've had some boards (all 2017) with no liquid that ended up having broken continuity in (I believe) 3v3_SUS at some points, and needed a wire. These were all non-liquid damaged, suspect an internal board fault.
                      • Electron67
                        • Oct 2021
                        • 8
                        • France
                        U1950 Pin1 : stuck at 0v, no pulsing.
                        R8162 : 0v on both side,
                        I'll dig with S5/3 rails connections and 3v3_SUS in same way.
                        RTC output has a strange shape (scope view), output level is not stable, sometimes, 2 voltage levels occur during Ton (stair step).
                        • Simplebeans
                          • Sep 2021
                          • 135
                          Ok thanks can you check the input on the U8160 now, I want you to check PIN #2 and #7, here we are checking for PP3V3_S0 voltage.
                          Also send the voltage measurements, again on U8160 for PINS #3 #5 and #6 please.
                          • reformatt
                            • Feb 2020
                            • 1501
                            https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
                            According to the OP, he wasn't getting to S4. Anything after this is meaningless. Understanding the power sequencing on these boards will save you lots of time.
                            • Electron67
                              • Oct 2021
                              • 8
                              • France
                              Thanks for advice.
                              Since PM_SLP_S5_L was stucked to 0v, no way to go further in power sequence.
                              Once R8115 was removed, i confirm that PM_SLP_S5 was forced to 0v by U0500. So, i directly connect PM_PWRBTN_L to R8115 Pin2 Pad => S4 conditions was granted and associated VR rise up. Following situation was : PM_SLP_S3_L stucked at 0v. I didn't want to play more with PCH output by-pass.
                              so i have some doubts about PCH health.
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                https://logi.wiki/index.php/User:Pie....2C_what_do.3F
