KB9028 Programming
  • reset1986
    replied
    Re: KB9028 Programming
    Yes, I got display
    perfect👍
  • mcplslg123
    replied
    Originally posted by reset1986
    ok, I found a vendor who programs me directly kb9028q, I made a request in the forum to have a file for this motherboard,
    in the end have you solved?
    Yes, I got display
  • mcplslg123
    replied
    Originally posted by mon2
    @mcplslg123, after you wired it up, did you program this component as the KB9028q or some other personality?
    as KB9028. RT8209F has this in list.
  • mon2
    replied
  • reset1986
    replied
    Thanks to all who responded. @khaahk, the pinout given by you is correct. I tried my level best but couldnt program ec with SVOD1 with custom made config file as provided by @khaahk. However, i got the job done with RT8209F by manually soldering the pins on kbd connector and khaahk's input is verified ok.
    @reset1986, KB9012/22 cant be replaced for kb9028. I already tried kb9022 on this very mb and it creates problem. KB9028 datasheet i couldnt find anywhere. I referred to Lenovo 330S schematic for basic understanding of KB9028.
  • mcplslg123
    replied
  • mon2
    replied
    Awesome! Thanks so much for the summary. Very much appreciated.
  • reformatt
    replied
    The SVOD comes with a breakout adaptor with various flip type ZIF connectors for each connector pitch. They also supply an assortment of ribbon cables of varying pinouts and pitchs. You select which one to use based on the ZIF connector on the motherboard you want to program, create the mapping and connect. Note there is a micro USB on the breakout board that you use to connect to the board via USB cable. This serves no function other than to connect the grounds together.
    Initial connect is a pin check (this is intended with board unpowered as it can damage the internal FET's of the programmer), check ground, then you plug in the power to the board. If the +3V for the EC is active, you then press Read ID. If successfully connected, you get the ID etc and you can then Read, Write, Erase etc.
    Did a search with FlexBV and got a couple of hits on Acers for KB9028Q
    Acer Swift 1 SF112-32
    Acer Spin 5 SP515-51N
    There might be a few cheaper alternatives, but I believe the SVOD is the most versatile. The software programming interface is pretty intuitive...it needs to be as you get almost zero support from these guys on the forum. You can buy an adaptor to program the EC's in a socket but it's quite expensive (140 euros). The SVOD comes with the ZIF adaptor and the ribbons for 178 euros.
    https://shop.svod-project.com/index....&product_id=54
  • mon2
    replied
    @reformatt4, if you create your own pin mapping, does the vanilla s/w function to perform the required r/w/e tasks ?
    What is required to r/w/e the KB9028q in terms of hardware ?
    The svod4 + which cable set ?
    If known, which logic board makes use of the KB9028q ? Would like to source the proper tool and a logic board to experiment with.
    Is the svod4 the lowest cost solution for the KB9028q programming ?
  • reformatt
    replied
    In SVOD3, you can create your own configuration file for the motherboard. If you have access to the EC pins, then you just meter it out to the SVOD (see attached pic). You just need to work out ribbon cable pitch, which is pin 1, if it's a drawer type connector whether it's top or bottom connection etc. I create my own usually as the ones in the online database frequently don't work.
    Maybe update your SVOD? They have SVOD4 out now.
  • reset1986
    replied
    Does anyone have the pinout for the KB9028 ? Datasheet ?
    Have the KB9012 datasheet now and appears to be normal SPI interface. What is the special case for the KB9028Q that cannot be programmed with a similar tool ?
    @reset1986 - your last post references the KB9012q which is not the same as the kb9028q. I thought I saw some ads on ebay that mention pre-programmed controllers for sale.
    If all of these devices are SPI interface, just use Total-Phase SPI bus analyzer to dump the transaction and then all secrets will be revealed.
    i had read kb9028q and kb9012q have their own pinout, i couldn't find kb9028q datasheet
  • mon2
    replied
  • piernov
    replied
    RT809F claims to support KB9028. I haven't tried.
  • reset1986
    replied
    Question:
    if a kb9012q arrives and we write correct and c could it solve?
  • reset1986
    replied
    The mb under repair is FAROE_Dis_X32_MB-MV 18742-1(HP). It came completely dead. Found 19V is not passing thru 1st dc-in mosfet. After diagnosis, replaced BQ24781 with BQ24780S and it solved that part of the problem. Next found +3V LDO is shorted, so removed the +3V PWM but still shorted. Removed KBC9028Q-c and short is gone. I've soldered new SY8286BRAC and KB9028Q-C(both new). DC jack is glowing now but mb doesnt turns on as kbc needs programming.
    I've SVOD1 which doesnt list kb9028 as an option. Still tried selecting kb9022 but doesnt work. The support has ended from SVOD-so cant download new config file. Schematic is perhaps not avlbl for this mb. I've RT809F which i beleive is also not capable of programming 9028 kbc(it can program kb9012/22).
    So can anybody give some idea how to program kb9028?? Please share config file for this mb. If anyone of sure of any other programmer which is capable of programming kb9028-i can buy a new one.
    Please suggest way forward.
    basically i have the same problem with the same motherboard, i didn't have ldo 3v, replaced pu453 SY8286BRAC not solved,
    replaced the kb9028q and returned the 3V and 5V ldo, power button 3V, but the board does not react, kb9028q not programmed,
    i used a ch341a and i used points
    KSO3 KSI4 KSI7 KSI6 KSI5 from diagram kb9012q but I can't get it to write in kb9028q, I also have a tl866cs and ezp 2019 but they don't solve, for now I have no solutions, if you have any news let me know
  • khaahk
    replied
    Vertyanov programmer lists it as this:
    KB_pins=32 LEFT DOWN 1MM KSO3=15 KSI4=28 KSI7=31 KSI6=30 KSI5=27 KB9028Q
  • mon2
    replied
    Hi. Personally have not worked with these components.
    Are they not just SPI interfaced?
    See here to see if it is possible with your programmer:
    https://www.alisaler.com/rt809f-prog...free-download/
    Do post your updates.
  • mcplslg123
    started a topic KB9028 Programming
    KB9028 Programming
  • sikocan
    KB9028 RT9809F Programming
    by sikocan
    Hi all, I'm having trouble detecting a SuperIO. ENE KB9028 using RT809F which says it supports KB9028. it's programmable through SPI Flash. From schematics I have connected the RT809F as follows. Pin 1 CS to > Pin128, Pin 2 DO to > Pin120, Pin 4 G to Ground. Pin 5 DI to Pin119, Pin 6 CLK to Pin126, Pin 8 VCC to Pin9 of SuperIO. I also rotated Pin 2 and Pin 5 thinking I made mistake. It simply doesnt get detected. I checked VCC it gets 3.3 from Power supply when DC jack is plugged in.
    I tried timing it like press read then Insert DC jack, or vice versa etc. No luck many times....
    07-28-2022, 02:59 AM
  • DynaxSC
    ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
    by DynaxSC
    I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
    This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
    Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
    02-10-2025, 04:52 PM
  • araxnido
    Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
    by araxnido
    Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
    When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
    06-10-2025, 09:26 PM
  • zesko
    MP2886A programming
    by zesko
    I have a board with a dead pwm on mp2886a. I order the chip without thinking about programming, and now I just realize my mistake.
    Someone know if it's 100% needed to program the chip ? And if so, how to program it ? I see some dedicated board and software but, software is a bit tricky to me, the bad part of the job...
    p.s : with the dead pwm chip, the GPU work fine when I disconnect the shorted pwm (6), with the new chip Pgood is 0 and the gpu doesn't start, so I guess it need to be programmed, or it's fake chip..
    p.s 2 : Sorry for my...
    07-28-2025, 02:07 PM
  • hikesync
    XMCQH128A​ Programming issue
    by hikesync
    Sup guys i've been having a trouble with XMCQH128A chips, this is the only model that always fails to programming. All the others models and brands like Winbond, cFeon, etc. All works fine. But i just cant do it with XMC chips, is there some specific program that i must use? (i am using NeoProgrammer)
    06-26-2025, 11:22 AM
