XMCQH128A​ Programming issue
  • hikesync
    • Nov 2016
    • 10
    • Brasil
    Sup guys i've been having a trouble with XMCQH128A chips, this is the only model that always fails to programming. All the others models and brands like Winbond, cFeon, etc. All works fine. But i just cant do it with XMC chips, is there some specific program that i must use? (i am using NeoProgrammer)
  • lotas
    • Jan 2016
    • 4656
    • Russia
    First, install a newer version of the program. Second, you need to read the Status Register, what it is set to, then remove all the checkboxes (remove protection) and press "Write", then erase, write a new dump, and set the Status Register (Protection) that was originally.
    • lotas
      • Jan 2016
      • 4656
      • Russia
      It doesn't work or you don't understand something?
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • artesano1969
        Reading and Programming ASUS iRog chips - EPF035 / EPF 036
        by artesano1969
        Well, I think this is the first time I'm sharing something here, I hope it will help anyone that, like me, is trying to repair one of those damm ASUS motherboards filled with iRog chips. I've written a manual following my experience and findings on fixing a dead ASUS Rampage IV Extreme (R4E).
        The ZIP file contains the guide and (almost) all the software I've used in the project. But I think it's worthy because it took me a lot of time to find out a cheap way to work with these chips from Explore with a bare CH341A programmer, and the original EP Console program is really hard to find....
        05-19-2024, 09:50 AM
      • akshayhackman
        Lenovo LA-G241P 8mb Bios programming issue
        by akshayhackman
        Lenovo LA-G241P 8mb Bios 1.8v programming issue with rt809f?? how to solve this issue please help expert
        10-20-2022, 12:48 AM
      • ugamazing
        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
        by ugamazing
        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
        12-17-2024, 07:05 PM
      • feherhollo
        WSON8 NEW Bios Chips READ, ERROR, ETC.
        by feherhollo
        I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
        I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
        For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
        11-26-2023, 09:33 AM
