820-2850-A: battery not detected
  • DrFalken
    • May 2008
    • 122
    Hi guys,
    a client brought me this MacBook Pro that doesn't detect the battery (he changed the original one with a compatible 2-POWER branded).
    The charger led is solid green and pressing the battery check button cause 5 blinks of the 8 leds
    I've measured voltages of U7000 (charger+battery, laptop turned off):
    Pin01 (CHGR_AGATE) = 0
    Pin02 (PPCHGR_DCIN) = 15.93V
    Pin03 (CHGR_ACIN) = 3.86V
    Pin05 (CHGR_ICOMP) = 1.0V – 1.43V
    Pin06 (CHGR_CELL) = 3.42v
    Pin07 (CHGR_VCOMP) = 1.10V – 1.40V
    Pin08 (CHGR_VNEG) = 1.70V – 2.09V
    Pin09 (CHGR_AMON) = 0.03V – 0.05V
    Pin10 (SMBUS_SMC_5_G3_SDA) = 3.41V
    Pin11 (SMBUS_SMC_5_G3_SCL) = 3.40V
    Pin12 (PP3V42_G3H) = 3.42V
    Pin13 (CHGR_RST_L) = 3.42V
    Pin14 (SMC_BC_ACOK) = 2.33V
    Pin15 (CHGR_BMON) = not measured
    Pin16 (CHGR_BGATE) = 3.57V – 11.72V
    Pin17 (CHGR_CSO_N) = 11.14V – 12.56V
    Pin18 (CHGR_CSO_P ) = 11.14V – 12.56V
    Pin19 (PP5V1_CHGR_VDD) = 5.07V
    Pin20 (PP5V1_CHGR_VDDP) = 5.02V
    Pin21 (CHGR_LGATE) = 0.56V – 0.61V
    Pin22 (GND) = 0.56V – 0.61V
    Pin23 (CHGR_PHASE) = 10.23V – 12.36V
    Pin24 (CHGR_UGATE) = 11.26V – 13.55V
    Pin25 (CHGR_BOOT) = 14.15V – 16.63V
    Pin26 (CHGR_SGATE ) = not measured
    Pin27 (CHGR_CSI_N) = 15.89V – 15.97V
    Pin28 (CHGR_CSI_P ) = 15.89V – 15.97V
    Voltages are changing as listed in about 5 seconds (i.e. CHGR_BGATE=3.57V...after 5 sec=11.72V...after 5 sec=3.57V...and so on)
    What can I check ?
    Thank you !!
  • DrFalken
    • May 2008
    • 122
    Re: 820-2850-A: battery not detected
    Removed U7000 and found this:
    Pin15 (CHGR_BMON) = short to GND
    I'll order and replace it...
    • mon2
      • Dec 2019
      • 14106
      Is the short still present with U7000 off the logic board ?
      • DrFalken
        • May 2008
        • 122
        No short circuit on the logic board on pad/pin 15.
        Without U7000 now the laptop turns on ONLY with battery + charger while before it turned on with charger or battery + charger
        Charger led is still solid green.
        • DrFalken
          • May 2008
          • 122
          U7000 changed with a brand new one.
          Actual voltages (without battery):
          Pin01 (CHGR_AGATE) = 14,79V
          Pin02 (PPCHGR_DCIN) = 16,4V
          Pin03 (CHGR_ACIN) = 3,87V
          Pin05 (CHGR_ICOMP) = 0,09V
          Pin06 (CHGR_CELL) = 3,39V
          Pin07 (CHGR_VCOMP) = 0V
          Pin08 (CHGR_VNEG) = 0,03V
          Pin09 (CHGR_AMON) = 0V
          Pin10 (SMBUS_SMC_5_G3_SDA) = 3,34V
          Pin11 (SMBUS_SMC_5_G3_SCL) = 3,34V
          Pin12 (PP3V42_G3H) = 3,39V
          Pin13 (CHGR_RST_L) = 3,39V
          Pin14 (SMC_BC_ACOK) = 3,24V
          Pin16 (CHGR_BGATE) = 0
          Pin17 (CHGR_CSO_N) = 0,16V
          Pin18 (CHGR_CSO_P ) = 0,16V
          Pin19 (PP5V1_CHGR_VDD) = 1V drop to 0
          Pin20 (PP5V1_CHGR_VDDP) = 1V drop to 0
          Pin22 (GND) = 0
          Pin23 (CHGR_PHASE) = 0,16V
          Pin24 (CHGR_UGATE) = 0
          Pin25 (CHGR_BOOT) = 0
          Pin27 (CHGR_CSI_N) = 1,5V
          Pin28 (CHGR_CSI_P ) = 1,48V
          Charger led is solid green.
          Laptop now is not turning on at all
          Update: PPBUS_G3H = 0,16V and 167 Ohm to GND
          • DrFalken
            • May 2008
            • 122
            Other readings:
            R7050 0 Ohm
            R7051 12.6 Ohm (should be 2.2)
            R7052 0 Ohm
            C7050 1216 nF
            • mon2
              • Dec 2019
              • 14106
              Few comments:
              1) PP3V42_G3H is a low value. Remove all power. Meter in resistance mode. What is the resistance to ground for PP3V42_G3H ?
              2) the current sense resistor values are critical. If wrong resistance then the wrong current will be sensed and will lead to shut down of u7000.
              3) are you confident that u7000 was properly soldered? Use high heat, initially low air pressure but with some flux on top side of u7000. Go in circles on top of u7000. Allow the chip to melt and sink naturally. Careful to not blow off surrounding parts. If needed, increase the air pressure. Then while balls are melted, use a tweezer to gently nudge the u7000 chip. It should move but will bounce back, naturally. This corrects any solder ball shorts. Do this a few times and allow the board to cool.
              Then check the current sense loop circuit again for u7000.
              4) also post the resistance to ground for ppbus_g3h. No power, meter in resistance mode.
              • DrFalken
                • May 2008
                • 122
                Few comments:
                Thank you for the help !
                1) 176.6 KiloOhm
                2) I've replaced R7051 with a 2.2 Ohm but no progress
                3) In doubt I've removed it and replaced with a another brand new one, checked the solders but same issue
                4) 171.8 Ohm
                PP3V42_G3H stuck at 3.39V
                • mon2
                  • Dec 2019
                  • 14106
                  4) 171.8 Ohm
                  That is a low resistance for PPBUS_G3H.
                  Remove all power.
                  Remove fuse F7040 (for now). Then check the resistance to ground (2k scale is ok) on F7040, pin # 1 and then # 2 of the SMD pads.
                  Which side has the very low resistance ?
                  Is it the source (U7000 side) or the sink (pin # 2) ?
                  If pin # 2 is with the low resistance, power up without F7040 installed.
                  Then check the voltage on pin # 1 of the SMD pad -> now do you see a proper voltage for PPBUS_G3H ?
                  If not, leave this fuse OFF till we can get a proper voltage on PPBUS_G3H.
                  Measure PPDCIN_G3H.
                  Post your readings.
                  • DrFalken
                    • May 2008
                    • 122
                    Remove all power.
                    Measure PPDCIN_G3H.
                    Post your readings.
                    F7040 removed:
                    PIN1 = 169 Ohm
                    PIN2 = 1.88 MegaOhm
                    PPDCIN_G3H (on Q7080 PIN8) = 16.29V - 16.48V
                    • mon2
                      • Dec 2019
                      • 14106
                      So the fault is in the source side = U7000 circuit. The input voltage to U7000 is good.
                      Perhaps one of the caps are damaged / shorted.
                      See attached.
                      Start with removing (just for now), the current sense resistors @ R7051 - remove only this one and then check if the resistance has changed on this line. Do not lose the resistor.
                      If no improvement on the resistance, proceed to remove the resistor @ R7052. Measure again. Do not lose the resistor.
                      Any improvement on the resistance ?
                      If you remove one leg of L7030 then you can create an isolated island of parts to narrow down which cluster of parts has the fault. However, L7030 will be with heavy solder and copper plane. Proceed to lift one leg but only if you feel comfortable.
                      Alternatively, as a guess, perhaps the fault is in one of the highlighted caps.
                      Consider to lift one leg of the 22uf @ C7040. Once the one leg is lifted, check the resistance to ground again on pad # 1 of fuse F7040.
                      Do not power up with these parts removed till the root cause can be fixed.
                      • DrFalken
                        • May 2008
                        • 122
                        See attached.
                        R7051 removed, resistance to GND on F7040 pad 1 = 168.8 Ohm
                        R7052 removed, resistance to GND on F7040 pad 1 = 168.8 Ohm
                        L7030 removed completely, resistance to GND on F7040 pad 1 = over 200 MegaOhm...
                        C7040 removed completely, resistance to GND on F7040 pad 1 = over 200 MegaOhm...
                        C7040 = 23.17 uF
                        • mon2
                          • Dec 2019
                          • 14106
                          This part can be put back.
                          So this means that the bad cap is upstream and on the pin # 1 side of the removed L7030.
                          Leave the inductor @ L7030 off the logic board for now.
                          a) What is the resistance to ground for L7030, pin # 1 ?
                          b) What is the resistance to ground for C7030 ?
                          You may have a shorted mosfet. Can check this next.
                          • DrFalken
                            • May 2008
                            • 122
                            Before I put back R7051, R7052 & C7040:
                            - resistance to ground for L7030, pin # 1 = 171.8 Ohm
                            I'm gonna put back R7051, R7052 & C7040 and update soon.
                            • mon2
                              • Dec 2019
                              • 14106
                              Ok. This confirms the short is to the left side of the schematic of U7000. That is, to the LEFT of L7030.
                              Still leave off L7030 till the root cause can be located. The other parts can be placed back on since they are innocent. If you do find that pin # 2 pad of L7030 sinks on the resistance then there is a fault on this group of parts but sounds like the fault is upstream.
                              • DrFalken
                                • May 2008
                                • 122
                                Put back R7051, R7052 & C7040:
                                L7030 pad 1 = 170 Ohm
                                L7030 pad 2 >20 MegaOhm
                                C7030 pin 1 >20 MegaOhm
                                • mon2
                                  • Dec 2019
                                  • 14106
                                  Ok. Post the resistance to ground for C7030.
                                  Mosfet Q7035 may be shorted.
                                  After the above resistance check, do the follow (resistance checks are always with the power removed)
                                  Measure & post:
                                  resistance between SOURCE (1-2-3) & DRAIN (5-6-7-8) of Q7035
                                  resistance between SOURCE (1-2-3) & GATE (4) of Q7035
                                  resistance between GATE (4) & DRAIN (5-6-7-8) of Q7035
                                  Post each reading.
                                  • DrFalken
                                    • May 2008
                                    • 122
                                    Measure & post:
                                    Post each reading.
                                    Q7035 left on board:
                                    resistance between SOURCE (1-2-3) & DRAIN (5-6-7-8) of Q7035 = 171.3 Ohm
                                    resistance between SOURCE (1-2-3) & GATE (4) of Q7035 = 46.9 Ohm
                                    resistance between GATE (4) & DRAIN (5-6-7-8) of Q7035 = 220 Ohm
                                    Sorry but I've to leave but will back tomorrow: if You have anything else to check, please post and I'll report tomorrow
                                    Thank you very much for your guide !
                                    • mon2
                                      • Dec 2019
                                      • 14106
                                      Remove Q7035 from the logic board.
                                      Then check the resistance to ground of L7030, pin # 1 pad again.
                                      If the resistance improves and is no longer low, proceed to:
                                      a) check the resistance across the same combination of pins on the removed Q7035 mosfet. Likely the low resistance values will show while the part is no longer on the logic board.
                                      b) check the resistance to ground of the PCB pads where Q7035 was soldered to confirm that U7000 is not to blame. If there are low resistance readings with Q7035 off, post the values and can troubleshoot further.
                                      Suspecting that Q7035 is defective and needs to be replaced.
                                      • DrFalken
                                        • May 2008
                                        • 122
                                        Q7035 removed:
                                        L7030 pad #1 > 20 MegaOhm
                                        Q7035 readings:
                                        resistance between SOURCE (1-2-3) & DRAIN (5-6-7-8) of Q7035 = 174.3 Ohm
                                        resistance between SOURCE (1-2-3) & GATE (4) of Q7035 = 49.6 Ohm
                                        Resistance of PAD 1-2-3 to GND = GND
                                        Resistance of PAD 4 to GND > 20 MegaOhm
                                        Resistance of PAD 5-6-7-8 to GND > 20 MegaOhm
                                        • spacez
                                          XPS 15 9520 - tpm device is not detected - NO ssd detected
                                          by spacez
                                          I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
                                          Service Tag: J2MSHW3
                                          |Express Service Code: 41518077843
                                          mother board LA-L402P REV 1.0(A00)​...
                                          08-18-2024, 10:54 PM
                                        • Nikan.e
                                          Inno 3d RTX2070 not detected - no I²C connection
                                          by Nikan.e
                                          Greetings and Salutations!
                                          I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
                                          The faulty DrMOS was removed, and the burned PCB area was milled away.
                                          All voltages are now good, but the GPU is not being detected.
                                          I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
                                          I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
                                          I thought these pins were used for communication during startup?!?
                                          On all...
                                          03-30-2025, 07:21 AM
                                        • superdota2
                                          HP 15s-FQ2552TU nvme drive not detected
                                          by superdota2
                                          HP 15s-FQ2552TU
                                          da0p5hmb8f1 rev f
                                          sn# 5CD138CCH4
                                          problem is power on but no display,no bios post
                                          i search bios here ,i found and it work and got display.
                                          https://www.badcaps.net/forum/showthread.php?t=104925
                                          second problem is nvme drive not detected in bios intel rapid storage,
                                          i tried a working nvme drive but still not detected in bios,
                                          also tried install system and install intel rapid driver,still not detected....
                                          06-21-2023, 09:36 PM
                                        • Scotchmist
                                          Lenovo thinkpad 15 itl g2 - No Hdd detected
                                          by Scotchmist
                                          Hi
                                          I got this laptop with bad onboard ram so edited the bios with SPD removal tool to disable the onboard ram and work with the ram slot - the laptop now posted so i thought all was good however when i put everything back together it will not boot to windows as no boot device found., In the bios is says hdd not detected, i disabled VMD in the bios but still the same, loaded windows on usb stick and windows install cannot find the hdd. I bought a second board that had water spill, repaired the damaged area and it posted ok but same issue no hdd detected.
                                          I have now tried...
                                          09-11-2024, 05:06 AM
                                        • titomno2
                                          Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                                          by titomno2
                                          Hi guys,
                                          On motherboard ACER AN515-52 type LAF951P.
                                          I fixed issue with not starting computer (it was the PQ201 component not working properly).
                                          But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                                          Basically some HDD spin but are not detected by the bios.
                                          Already tried following:
                                          checked the 4 data lines
                                          #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                                          #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                                          07-28-2024, 08:30 AM
