what's involved in replacing the super IO?
  • kjchatman
    • Dec 2012
    • 209
    • united states
    i have an hp envy 17m-bw board and it looks like the kb9028q will need to be replaced. will this need to be programmed? is there a seperate chip that holds the programming? perhaps one in soic8 form factor?
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Re: what's involved in replacing the super IO?
    Yes, it needs to be propgrammed first.
    Please have a look at this. Everything is explained:
    https://www.youtube.com/watch?v=4i7zLfzTrVo&t=54s
    • Destroyer-Br
      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
      by Destroyer-Br
      I'm working on an Acer Nitro 5 unit with the following specs:
      • Motherboard: LA-J871P Rev: 1B
      • Model: Acer AN515-55-59MT
      • S/N: NHQ7JAL00403906A973400
      • SNID: 03902728734
      Initial Issue
      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
      04-17-2025, 08:18 PM
    • Astray
      MSI GS75 No Power
      by Astray
      Hello, working on a laptop (MSI GS75 9SG-242US, Core i7-9750H, 2080 Max Q) and after replacing the screen and forgetting to disconnect the battery prior, I have no visible indications of power anywhere. It was working perfectly fine prior to the screen removal and replacement. Checked the motherboard PCB visually near the LCD connectors and didn't really see any indications of damaged surface mounted components but haven't looked under a microscope yet.
      Battery charging light isn't turning on when plugged in and pressing the button does nothing regardless of being on battery power...
      04-14-2024, 09:35 AM
    • Loki_Fido
      Clean ME for VAIO please. Super I/O just got replaced
      by Loki_Fido
      Hi ya folks,
      Hope everyone's having a nice day.
      I recently replaced the super I/O chip and now I believe i need a clean ME for the system to come online. Cause i started the laptop and it did not start.
      Laptop details
      Sony VAIO
      Product name VJS111
      Model Number VJS111D12N
      Serial Number 7014633
      Motherboard markings
      FEILONG MB REV 1.03B
      UMT-KS 2V 94V-0 E49068 A7 1545 07-01
      Original bios file attached
      SUPER I/O chip model ITE IT8528VG
      Thanks a million in advance folks...
      05-11-2025, 11:40 PM
    • Paul20
      Swap Super I/O Lenovo Ideapad
      by Paul20
      Hi, I would like some advice.
      I have two motherboards, one with a dedicated GPU and the super I/O with obvious burn marks on it, and another working motherboard without a dedicated GPU.
      My question is: can I swap the super I/O from the motharboard without dedicated GPU to the one with dedicated GPU? Will it work anyway or is that super I/O taken from the motherboard without GPU only good on motherboards without dedicated GPU?
      The motherboards are exactly identical even in terms of versions...the only difference concerns the dedicated GPU in one and not in the other.​
      11-27-2023, 10:47 AM
      Thermal pad thickness for various laptop GPU / Graphics Cards
      ASUS Dual RTX 2070 OC 8GB
      ASUS ROG STRIX RTX 3080 OC
      ASUS ROG STRIX RTX 3090
      ASUS TUF Gaming RTX 3080 OC Edition
      ASUS TUF GTX 1660 S-O6G GAMING
      EVGA RTX 3060 Ti XC GAMING 8GB
      EVGA RTX 3060 XC GAMING 12GB GDDR6
      EVGA RTX 3080 FTW3 ULTRA GAMING
      EVGA RTX 3080 TI FTW3 ULTRA GAMING
      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
      Gainward RTX 2080 Phoenix GS Specs
      Gainward RTX 3070 Phoenix 8GB
      Gainward RTX 3080 Ti Phoenix
      GIGABYTE AORUS RTX 3080 MASTER 10G
      02-09-2024, 08:08 AM
