Asus x442u cant use adaptor
 Re: Asus x442u cant use adaptor
 ?? Can you explain ?do you think this has something to do with this 5v shuffle voltage?
 This is from your earlier posts. This power source is from the AC adapter.
 How does this voltage reach the ACN / ACP pins if the mosfets are expected to be off?Comment
 so it's like this, when the adapter is connected, pin number 5678 acfet has 19v, and pin 1234 is 0v
 then on pin 1234 rbfet 0v too, but on pin 5678 there is 5v
 I also wonder why it can be like this, maybe there is a problem in the battery line, or is there a problem with the regn which is leaking and draining 5v?Comment
 Do you feel comfortable with the replaced charger IC ? Consider to flux it and hot air till it swims into place with tweezers. Just to rule out any possible shorts underneath the QFN package pins.
 Also observing that the replacement is from TI vs. the original used by Asus. According to the internet, the 2 devices are cross compatible. Is this 100% confirmed ?Comment
 Yes, I'm sure sir, I've replaced with 3 ICs, but still the same one of the ICs is indeed damaged, but the other 2 ICs are still good, and work on other Mobos, after I searched, there is indeed a Regn that can penetrate ancDo you feel comfortable with the replaced charger IC ? Consider to flux it and hot air till it swims into place with tweezers. Just to rule out any possible shorts underneath the QFN package pins.
 please open this picture from the first order shows the path of screenshot 4 until screenshot 8Comment
 Thos is quite possible, since REGN is about 6V and is generated internally inside the chip. If possible, remove the chip and measure resistance between REGN and ACN/ACP pins on the motherboard. Maybe this is shorted not inside the chip, but on the mobo itself.Comment
 Check to see if you have a load switch at PU8802.
 You are missing +3VA_EC. Yet, you have +3VA.
 The load switch passes through +3VA to create +3VA_EC. Check the schematic posted earlier to compare against your logic board. If found, measure the voltage of the enable pin of this load switch. Post your updates.Comment
 thanks sir, but do you mean the load switch is PU8001 on boardview?
 IC which has 14 pinComment
 after I changed the load switch then 3va ec appeared only 0.07v sirComment
			by LvsitanoI am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
 First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
 I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
 First...
			This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
			This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
			This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
			This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
