Macbook Air A1466 EMC 3178 Board 820-00165-A no power
  • stellablu
    • Jan 2022
    • 10
    • Italia
    Hi everyone!
    I'm working on a Macbook Air A1466 EMC 3178 Board 820-00165-A that doesn't power on. No liquid damage. No fan. I've tried various power adapter, no green nor orange light.
    PPBUS_G3H is 8.18V, and from what I've read on other threads it seems that SMC is not communicating to the ISL chip, but I don't know what to do next.
    Thanks in advance for help or advices.
  • mon2
    • Dec 2019
    • 14027
    Re: Macbook Air A1466 EMC 3178 Board 820-00165-A no power
    Hi. See attached. Post the requested voltages.
    Your case may be similar to another over the weekend. There is a one-wire circuit (Maxim / Dallas Semiconductor / now Analog) that communicates with the external adapter to light up either the green / orange or no LED status.
    Confirm the contacts on the magsafe connector are clean - use alcohol.
    Are you using an official adapter ?
    Post the voltage on the one-wire signal line.
    • mon2
      • Dec 2019
      • 14027
      Also review this thread - your problem may be the same.
      https://www.badcaps.net/forum/showthread.php?t=102720
      • reformatt
        • Feb 2020
        • 1401
        https://repair.wiki/w/A1466_2015-201...9D_MacBook_Air
        • reset1986
          • 308
          • italia
          Originally posted by stellablu
          Hi everyone!
          check that there are no shorts and check the voltage on the lines, smc_bc_acok,
          • stellablu
            • Jan 2022
            • 10
            • Italia
            Hi, thank you for your help.
            I'm using original adpters, and the contacts on the magsafe are clean.
            Here are the voltages:
            R7005 15V
            R7006 8.18V
            PPVIN_G3H_P3V42G3H 14.75V
            L7095 3.42V
            • stellablu
              • Jan 2022
              • 10
              • Italia
              Thank you for the link, it is very helpful
              • stellablu
                • Jan 2022
                • 10
                • Italia
                Thank you for the advice.
                I checked the voltages, there are no shorts, and smc_bc_acok seems fine.
                • mon2
                  • Dec 2019
                  • 14027
                  Post the voltage of SYS_ONEWIRE.
                  • reformatt
                    • Feb 2020
                    • 1401
                    If PPBUS_G3H is 8.2V then the SMC is not communicating with the ISL chip. Reasons for this are well covered in the RepairWiki link I posted earlier. The most common cause is SMC_RESET_L being stuck low and it's usually related to J6100 having crap on it. Clean it with a toothbrush and IPA even if it looks ok.
                    • stellablu
                      • Jan 2022
                      • 10
                      • Italia
                      SYS_ONEWIRE is 3.399V
                      • stellablu
                        • Jan 2022
                        • 10
                        • Italia
                        SMC_RESET_L fluctuates between 1.5V-0.4V
                        It might be SMC_RESET_L being low.
                        • mon2
                          • Dec 2019
                          • 14027
                          Have you cleaned J6100 with alcohol as per @reformatt's suggestion ?
                          • stellablu
                            • Jan 2022
                            • 10
                            • Italia
                            SOLVED!!
                            It was R5100, changed it, now the laptop turns on and works fine . I'm so happy
                            Thank you all for the help.
                            • mon2
                              • Dec 2019
                              • 14027
                              Good job !
