A1502 820-3476-A green light no power on
  • nahuelaune
    • Jan 2022
    • 8
    • ARGENTINA
    Hi! I've got this laptop with this problem. It's got green light and after a few seconds it turns orange, the power supply shows a 0.01 Amp. I checked the power aliases and this is what I've got:
    -PPBUS_G3H 12.58V
    -PPBUS_S5_HS_COMP 12.58V
    -PPBUS_S5_H5_OTHER5V 12.58V
    -PPBUS_S5_H5_OTHER3V3 12.58V
    -PPDCIN_G3H_ISOL 18.27V
    -PPDCIN_G3H 18.27V
    -PP3V42_G3H 3.44V
    -PPVRTC_G3H 3.35V
    -PP5V_S5 5V
    -PP5V_S4 0V
    -PP5V_S0 0V
    -PP3V3_S5 3.35V
    -PP3V3_S4 3.35V
    -PP3V3_SUS 3.35V
    -PP3V3_S3 3.35
    -PP3V3_S0 0V (SHORT TO GROUND)
    -PP3V3_S0_FET 0V (SHORT TO GROUND)
    I injected 1.5v into pp3v3_s0 and the only thing I could touch was heating is the GPU. Would appreciate any help.
    Also I took out R5080 because I measured it and I think it's also short to ground as I read in some forum.
    When I plug the battery the power supply goes up to around 0.7 amp, so I assume it's charging.
    Thanks!!
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: A1502 820-3476-A green light no power on
    with this boards normally PP3v3_s0 is shorted around the sound chip (U6201) so check C6305 and C6306.
    Also check impedance on L7630
    • nahuelaune
      • Jan 2022
      • 8
      • ARGENTINA
      Hi bluestone, I'm checking those capacitors. I put the multimeter in 200 ohms and it shows 0.1 ohms in L7630, is it ok? Thanks for your answer!
      • nahuelaune
        • Jan 2022
        • 8
        • ARGENTINA
        I checked all caps around the sound chip and none of them got hot, I injected 3amps and isopropyl alcohol. still get hoy the GPU, as I can feel.
        • bluestone
          • Jun 2011
          • 343
          • Ghana
          This model does not have a GPU, Check L7630 in diode mode and post.
          • nahuelaune
            • Jan 2022
            • 8
            • ARGENTINA
            Sorry, I thought the little rectangle in the CPU chip was the GPU. checked L7630, beeps... OL in the multimeter.
            • nahuelaune
              • Jan 2022
              • 8
              • ARGENTINA
              Some extra information, I bought this computer to take some parts but I tried to fix it first. Under the keyboard It has something like water damage, it's from the 3.5mm audio jack, ThunderBolt, etc. so maybe it had a liquid damage, I can't see corrosion because probably (90% sure) someone tried to fix it before.
              EDIT: in L7630 the multimeter says 0.0.
              • nahuelaune
                • Jan 2022
                • 8
                • ARGENTINA
                I found corrosion in u8005, I took it but the short is still there.
                • bluestone
                  • Jun 2011
                  • 343
                  • Ghana
                  That's the PCH if it reads 0.00 in diode mode meaning your CPU is fried. Option ow is to replace CPU or replace the whole motherboard
                  • nahuelaune
                    • Jan 2022
                    • 8
                    • ARGENTINA
                    Ok bluestone, thank you for your time!! Is there any other measurement I could do to be completely sure that the problem is the pch? I mean because of the corrosion and maybe liquid damage.
