Lenovo T480s completely dead
  • Andreasbest
    • Aug 2014
    • 1236
    • Hellas ( Greece )
    Re: Lenovo T480s completely dead
    Docking station arrived, no power on the laptop at all. 0v on all pins
    With charger directly on laptop i get 5v on several pins of type c charger port.
    • khaahk
      • Dec 2013
      • 833
      • Estonia
      You stated earlier that you used the 0 filled TB bios? Did you try to write the T480s file as TB firmware?
      • Andreasbest
        • Aug 2014
        • 1236
        • Hellas ( Greece )
        I flashed the 0 filled bios on TB bios chip (only 1MB)
        Can't flash the T480s bios on TB chip, TB chip has very low capacity, only 1 MB as i stated.
        • khaahk
          • Dec 2013
          • 833
          • Estonia
          I meant the TBT.ZIP file (and the T480S TBT.BIN file inside it) from the SMDFlea topic. It is 252KB size.
          • Andreasbest
            • Aug 2014
            • 1236
            • Hellas ( Greece )
            No i didn't, i only flashed the 0 filled file from that topic.
            What do i miss here?
            • Andreasbest
              • Aug 2014
              • 1236
              • Hellas ( Greece )
              #26
              Today i flashed it, no change. Still 5v on some pins of usb c instead of 20.
                • 22424
                post the resistane to gnd on TBT_VBUS20 and USBC_VBUS20
                • Andreasbest
                  • Aug 2014
                  • 1236
                  • Hellas ( Greece )
                  #28
                  TBT_VBUS20 right after PF1 fuse is 410mV
                  USBC_VBUS20 right after PF2 fuse is 5V
                  • khaahk
                    • Dec 2013
                    • 833
                    • Estonia
                    #29
                    I think you can connect the charger to the docking port directly - does the value on PF2 change from 410mV to higher level? If also 5v then i would start to look towards PD controller, U222. If you have received the USB-C tester it would be nice to see how much current is drawn, my HP Elitebook for example can charge the battery from 5v USB charger when in off state. But not turn on from this adapter because of low wattage. If the lenovo can do it - then you can see if it charges and maybe even turn on from battery if left to charge for a while.
                    It is a lot of work to troubleshoot USB-C charging.
                    https://www.richtek.com/Design%20Sup...Document/AN056
                    • Andreasbest
                      • Aug 2014
                      • 1236
                      • Hellas ( Greece )
                      #30
                      I'm still waiting for the tester.
                      The dock arrived with it's 90w psu, i connect it and the voltage on PF2 is still ~400mV
                        • 22424
                        Check C299 and USBC_HV_GATE and TBT_HV_GATE voltage
                        • Andreasbest
                          • Aug 2014
                          • 1236
                          • Hellas ( Greece )
                          #32
                          C299 ~400mV
                          I checked USBC_HV_GATE @ PR46 (i hope it's correct part) 0v
                          Not sure where to measure TBT_HV_GATE, PR41 and PR45 are missing from the MB.
                          • khaahk
                            • Dec 2013
                            • 833
                            • Estonia
                            #33
                            Either using USB-C or docking port, the 5V should be at PL1 or PL2 (the same VIN20_IN), is the 5V there? The charger BQ25700 is able to use that 5V input to boost it up and charge the battery, is it happening? Does the voltage rise on battery when charger is connected? If left for long to charge the pc should work normally on battery.
                            If the above is true then measure resistance on C300, C301, C9597, C9598 to GND, they should be similar and high resistance.
                            • Andreasbest
                              • Aug 2014
                              • 1236
                              • Hellas ( Greece )
                              #34
                              PL1 and PL2 have no voltage at all.
                              Also no voltage at all pins of battery connector (with battery connected)
                              Only place i see voltage around there is PF2 5V
                              • khaahk
                                • Dec 2013
                                • 833
                                • Estonia
                                #35
                                Take resistance measurements relative to GND on U222 pins 5,7,30 - also on PL1, PL101, VSYS15. Look for abnormally low resistances.
                                • Andreasbest
                                  • Aug 2014
                                  • 1236
                                  • Hellas ( Greece )
                                  #36
                                  Hello! Sorry for the delay but i work away from bench most of the week.
                                  5@ 0v
                                  7@ 3.3v
                                  30@ 1.7v
                                  PL1@ 5.7Ω to the GND, both pins
                                  PL101@ infinity Ω to the GND
                                  VSYS15 (measure it at F1) @ infinity Ω to the GND
                                  • Andreasbest
                                    • Aug 2014
                                    • 1236
                                    • Hellas ( Greece )
                                    #37
                                    Finally the USB Type C tester is here.
                                    Let me know what test you want exactly yo do.
                                    • khaahk
                                      • Dec 2013
                                      • 833
                                      • Estonia
                                      #38
                                      Leave the USB-C tester for now, you have low resistance on 20V line, try locating where the 5 ohms comes from, try removing PL1, PL2, if needed PR101. If you have lab psu and thermal imager then make use of them.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1236
                                        • Hellas ( Greece )
                                        #39
                                        I can use a bench PSU too, where exactly do you want to apply voltage?
                                        • khaahk
                                          • Dec 2013
                                          • 833
                                          • Estonia
                                          #40
                                          At first try to narrow the location down, remove PL1 - find at what part of it is still 5 ohms, depending on the result remove PL2, if needed remove PR101 also.
                                            Lenovo ThinkPad T480s Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T480s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480s boardview and T480s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 02:34 PM
                                            09-06-2024, 02:30 PM
                                            09-06-2024, 12:00 PM
                                            09-06-2024, 11:50 AM
                                            09-06-2024, 11:40 AM
