A2337 new M1 MacBook Air problem Logic Board related, no video backlight 820-02016
  • mon2
    • 14672
    Review the first pic in post #80 of this thread.
    Move the red meter probe to the other side of the caps. What is the resistance?
    • corintosh
      • Dec 2024
      • 29
      I hope the pictures show everything well enough. Flipping the side and measuring there gives the exact same values.
      • mon2
        • 14672
        Can you share the pic for the CP600 block of parts?
        • corintosh
          • Dec 2024
          • 29
          I should have included more info, it is already part of the ones I already uploaded. They are at the top.
          • corintosh
            • Dec 2024
            • 29
            Do you have another idea / anything I could try or check or is it time to assume the board is internally shorted?
            • inflex
              • Aug 2012
              • 545
              There's more caps off to the side of the screen connector and near the main storage caps that you've already removed.
              Do you have the boardview & schematic and a boardviewing program? This is FlexBV5 ( https://pldaniels.com/flexbv5 ) which has a free edition which may help you out here.
Name:	Screenshot at 2025-01-08 00-04-01.png
Name:	Screenshot at 2025-01-08 00-03-49.png
              YouTube Repair Videos - https://www.youtube.com/user/19PLD73
              FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
              • corintosh
                • Dec 2024
                • 29
                Thanks, I do already use flex and the schematic for my board. I removed all caps that flex showed to be part of the lcd backlight out. This includes the ones next to the screen connector and the 4 on each side next to the main storage caps.
                I included photos of the board with the caps taken off of all the regions.
                If it is time to stop trying other things I will likely sell it for parts. I don‘t think it is worth to buy a replacement logic board as I probably would have to replace married parts.
                • inflex
                  • Aug 2012
                  • 545
                  Right, sorry about that one - I misinterpreted your pictures where you had the LCD connector + removed caps next to them in the next picture, definitely my bad there.
                  Did you also remove RP831 ? It's a resistor that takes the voltage back across XWP801 (internal link) to the controller. If you remove that and the short remains, then I'd say you've got a bad board likely. If the short disappears then look at the FB line parts and the controller
Name:	Screenshot at 2025-01-08 00-40-24.png
                  • inflex
                    • Aug 2012
                    • 545
                    I just realised, YES, you already have removed those parts
                    Try remove the controller, just for the hell of it too.
                    • corintosh
                      • Dec 2024
                      • 29
                      Thanks for staying on it with me!
                      The controller would be UP800? I will try it. I am still quite sure that when injecting voltage the very first time (still with RP831 on) it created a mark on it. Refering to post 76 in this thread.
                      • inflex
                        • Aug 2012
                        • 545
                        Correct, yes UP800. Normally I'm not one to subscribe to the notion of pulling chips without first determining a viable cause to blame them but sometimes after all this sort of work you end up just throwing caution in to the air and trying. At least it's a comparatively simple chip. Other possibility of course is the display connector itself.
                        • corintosh
                          • Dec 2024
                          • 29
                          Alright I will give it a try. I am trying to learn as much as possible - could you explain your thought process behind this? I would have guessed the chip was out of the equation since we removed the path to it when RP831 was removed.
                          • mmglipetsk
                            • Aug 2025
                            • Россия
                            #113
                            Hello. In my case there was no display backlight due to the CP870 capacitor. It's surprising that the Led driver didn't fail
                            • kamil83
                              • Apr 2017
                              • sweden
                              #114
                              MacBook Air A2337, motherboard number 820-02899-A. In short, this Air had a damaged backlight. The screen has been tested and works fine on an external monitor. I reinstalled the operating system, but nothing changed. PP5v_BKLT_A/B 5V
                              PP5v_BKLT_D 5V
                              PP5V_S2 5V
                              PP5V_SW_LCD 5V
                              P5VS2_PWR_EN 1.8V
                              P5VS2_BST_R 8V
                              P5VS2_SW 5V
                              PPBUS_5VS2_VIN 5V
                              PPVOUT_LCDBKLT - Doesn't short 0V
                              FP800 - Both sides 13v
                              BKLT_EN_R & BL_PWR_EN - 1.8v
                              IPD_LID_OPEN_1V8
                              PP3V3_SW_LCD
                              QP800 3pin 13v 4 pin 12.8v 6521pin 0v i changed
                              LP800 0.014V On both sides (should be 12? / no short)
                              UC300 & UP800 Replaced with tested one - no difference.
                              Just to clarify, no backlight - I can see display very dim.
                              • ledbylight
                                M1 A2337 Macbook - No Display, likely due to logic board
                                by ledbylight
                                Hi all!
                                This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                11-04-2024, 06:36 PM
                              • Guest
                                A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                by Guest
                                Hello all!
                                Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                09-26-2024, 03:31 AM
                              • mkdj
                                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                by mkdj
                                About me, my goal and the equipment I (don't) have:
                                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                About my issue and my goal:
                                A friend of mine has a MacBook Air M1 A2337 that does not...
                                04-03-2025, 08:28 AM
                              • korben_dallas
                                Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                by korben_dallas
                                Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                MY QUESTION:
                                I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                02-14-2024, 12:23 AM
                              • Adogabriel100
                                where to get trusted CD3217. Problem with A2337 Macbook Air
                                by Adogabriel100
                                Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                09-06-2024, 12:06 PM
