sony svf14 HK8 no power
  • pc.heidari
    • Apr 2020
    • 14
    • Iran
    hi . i have a sony svf14 da0hk8mb6e0 rev e .
    no power
    main have 3.3 and 5 pcu . bios pin 8 have 3.3 .
    kbc chipset have 3.3 pcu and other .
    but on pwrbtn (nbswon ) are 0.3 v
    on kbc pwrbtn out ok
    lid sw ok
    rsmrst ok .
    bios check
    why no any voltage on power btn ? laptop dont power
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: sony svf14 HK8 no power
    Make a short circuit of the KBC leg 15 (EC_PWRBTN #) to ground and see if the motherboard starts.
    • pc.heidari
      • Apr 2020
      • 14
      • Iran
      i have done this but no power . still on power btn no voltage .
      • mon2
        • Dec 2019
        • 14334
        Remove D1 diode and test again.
        • pc.heidari
          • Apr 2020
          • 14
          • Iran
          d1 not on board . empty
          • mon2
            • Dec 2019
            • 14334
            What is the resistance to ground for NBSWON# on the switch ? Red meter probe on NBSWON# and black meter probe to ground.
            Confirm with the meter, that the switch is working. When you close the on/off switch, does the meter show close to 0 ohms ? I am assuming that the ON/OFF function is a simple mechanical switch for this design. Not sure if there is a logic board with the on/off switch.
            • pc.heidari
              • Apr 2020
              • 14
              • Iran
              resistance nbswon# with gnd are 7.6 m/ohm .
              • mon2
                • Dec 2019
                • 14334
                What is the resistance when you press the on/off button ?
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • PopsCaps
                  Sony Bravia KDL-40V2500 that will not power on
                  by PopsCaps
                  I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                  I do not hear any sound and I cannot see any backlight.
                  I have tried disconnecting every cable on each board one at a time to see if anything changes.
                  The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                  My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                  03-25-2025, 11:23 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  09-06-2024, 05:59 AM
