Macbook A1707 short on PPBUS - nothing gets hot
  • JM1010
    • Sep 2021
    • 16
    After using a bad charger (cord chewed by dog...) Macbook died.
    Getting 20V and oscillating 0 and .2amp on amp meter
    PPBUS is shorted (.8V)
    After checking resistance with Vcore (ok), injected 1 amp, then 2 finally 3 amp on PPBUS and nothing seems to get hot except the PCH (barely tolerable to the touch at 3amp.)
    If I can't detect anything getting hot @ 3 amp, what else can I do??
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14667
    Re: Macbook A1707 short on PPBUS - nothing gets hot
    PCH getting hot often means it is game over. However wait on additional feedback from others.
    • reformatt
      • Feb 2020
      • 1501
      Use a thermal camera and voltage injection @1V. 3amps should light up like a Xmas tree.
      • JM1010
        • Sep 2021
        • 16
        Thanks Mon and Reformatt for chipping in. I'm dealing with a PARTIAL short @ 50 ohms and this makes it difficult to find anything warm. I wish I had a thermal cam but i don't. I carefully inspected the whole board, applied IPA etc, nothing really gets hot.
        As it currently stands PPBUS is partially shorted ( priority) as well as PP5_S5 and PP4V.
        The PCH is quite warm but I think it may be normal or due to one of the shorted rails.
        I wonder if there are other ways to identify the source of a partial short where nothing really gets hot....
        • mon2
          • Dec 2019
          • 14667
          Locate and remove, for now, fuse F7000 off the logic board.
          Remove all power. Meter in resistance mode.
          What is the resistance to ground on F7000, pin #1 ? pin #2 ?
          Respectively, trying to locate the short and if it is on the source side (U7000 circuit) or sink side (after the fuse).
          • JM1010
            • Sep 2021
            • 16
            Exactly what I had in mind Mon. Really hope it's on the source side.... Irrespective of which side it is, what would be the next step? On the list for tomorrow.
            As a side note I also have some PP5 and PP4 rails shorted. Could (should) be related to same problem. Again this is not a water damage board. All happened at once. Weird.
            I'll buy some freeze spray, should help till I can put my hand on a thermal cam such as the seek pro.
            • mon2
              • Dec 2019
              • 14667
              We do not own a thermal camera, yet, but have had very good luck using IPA from Costco pharmacy dept. The designs of the camera keep improving daily and the price continues to drop.
              We have used 0v8 of voltage injection and this process highlighted the IPA soaked tantalum that was at fault. Personally would not go much higher as we do not yet know where the rail is going. Freeze spray is expensive as compared to IPA.
              The ISL9240 is now readily available offshore - did ping Mobile Sentrix to request them to carry the device as well. We have a bunch of them in transit through Aliexpress, if you are in need of it.
              With IPA over suspected parts, the heat mists the alcohol quickly so you can home in on the bad part.
              In the meantime, you can also try:
              Remove all power. Meter in resistance mode (2k should be ok).
              Then use the meter to check the resistance to ground of each mosfet linked to U7000:
              source to drain
              source to gate
              gate to drain
              Looking for any low resistance values on the mosfet which may be a factor of the low PPBUS_G3H value and low resistance.
              • JM1010
                • Sep 2021
                • 16
                Thanks a million Mon. I owe you one. Maybe a beer in Windsor some day
                • reformatt
                  • Feb 2020
                  • 1501
                  3 amps into 50 ohms....you'd have to be injecting 150V for that to be the case, so your fault is on a sub-rail.
                  You either have a shorted decoupling cap, or a shorted FET/power IC on one of the buck converters. Shorted caps can be found with IPA and voltage injection, but 0201 caps are very easy to miss using that method. A better alternative is to use a Rosin atomizer dispenser pens instead.
                  For the dual FET buck converters, just measure drain to source (or Vin to Vsw/Vsw to GND) on each sub-rail. For the power IC's (like U7210 etc), measure Vin to SW (or SW to GND) for a short. If you have a high side FET failure on a sub 2V rail, that usually results in destruction of the silicon.
                  • JM1010
                    • Sep 2021
                    • 16
                    Reformat, was tired hope it's a typo. Was careful to keep voltage below 2V and current below 3 amp.
                    Mon regarding the PPBUS short, I didn't have to pull out the fuse(s) as I think I have my answer and I'm pretty sure the short is on the load side (unfortunately).
                    Both the ISL coil L7030 and the Q7030/40 mosfet gates are not shorted. Only the Q7040 output is shorted. (PPBUS).
                    I've poked around and this is what I have thus far. Some of these rails have pretty low resistance to ground. Unsure which are fine, need to investigate some more.
                    PP5vs5 good, pp5V_S0 3 ohms
                    PP3V3, pp3v3s5, PP3V0 are fine but PP3V3_TBT 1 ohm,
                    L2950 VR09V 1 ohms .. should be around 500 I think
                    pp1V2_s3 150 ohms
                    PP1v_pch 75 ohms (L8000)
                    pp1v8 OL
                    PP1V0 OL
                    u5400, everything low ohms / shorted including pp3v3_S0 (1.5 ohms) except cpuhi_ioout
                    The GPU mosfet QA640 and 650 have peeled on top, probably normal as these probably run hot. Unsure.
                    • mon2
                      • Dec 2019
                      • 14667
                      pp5V_S0 does not look healthy.
                      Disconnect (if not done already) the LCD; keyboard; trackpad.
                      Be sure that the keyboard connector area is clean of any possible corrosion. IPA is great with a Q-tip.
                      The above rail is all over the logic board starts with a load switch. See attached.
                      What is the resistance to ground of Pin # 1 (U8209) ?
                      • JM1010
                        • Sep 2021
                        • 16
                        U8209 Pin 1 is pp5v_s4 @ 4 ohms. Other 5V: pp5V_S0 @ 3 ohms, PP5vs5 is good
                        Correction PP3 rails
                        PP3V3, pp3v3s5, PP3_S0 are fine PP3_S0_LEFT is 4 ohms and PP3V3_TBT 1 ohm. Maybe something funny going on with U8295.
                        The board is out of the case. I'll check the connectors nevertheless.
                        • mon2
                          • Dec 2019
                          • 14667
                          See attached.
                          Locate L7600 inductor. A bit of a pain but lift one leg of this coil - carefully. Use flux and heat to melt the large SMD pad to isolate the 5V rail.
                          Do not power on in this condition.
                          What is the resistance to ground on L7600, pin #1 pad ? pin #2 pad ?
                          • JM1010
                            • Sep 2021
                            • 16
                            Thanks Mon, just momentarily pulled it out to take a reading. Unfortunately this short is on the PP5_S4 side (3.4 ohm)Sorry I forgot to record the other side but it did not beep.
                            So that leaves me with a problem on PPBUS, PP5V_S0, PP5S4 but not S5, PP3V3_TBT, PP3V_S0_left but not PP3VS0. Oh My.... for a no liquid laptop it's quite an handful. Any chance they have one or two things in common? Trying to solve this puzzle logically
                            • spidertnt
                              • Jul 2016
                              • 34
                              I have had 2 of these boards with no liquid short on c4206 and c4205
                              • JM1010
                                • Sep 2021
                                • 16
                                Funny coincidence Spider, Rene from Macbook Repair Ottawa tried to fix my board and removed one of these caps. Caps were fine, shorts are still there. Board is back with me to fix. Cheers.
                                • mon2
                                  • Dec 2019
                                  • 14667
                                  A good tool to have here is a LOW ESR meter. They are not that expensive and you can build one yourself from the article on this website using an Arduino.
                                  With the tool, you can quickly test each part to locate ideally the bad one based on the ESR reading.
                                  There is a youtube on this topic. Let me see I can find it and link it. Just a FYI.
                                  • mon2
                                    • Dec 2019
                                    • 14667
                                    https://www.edaboard.com/threads/eas...boards.396794/
                                    Watch the video...
                                    • JM1010
                                      • Sep 2021
                                      • 16
                                      Hi Mon, are you suggesting an ESR is needed to move ahead with identifying the shorts on my rails eg PP5VS4? I still wonder what these rails have in common as all the problems happened at the same time.
                                      • mon2
                                        • Dec 2019
                                        • 14667
                                        Can you clarify which side of PP5V_S4 is appearing to be shorted ?
                                        Is it L7600, pin # 2 = U7650 = source of the voltage rail ?
                                        Or L7600, pin # 1 = sink of the voltage rail ?
                                        • CG_Dionysos
                                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                          by CG_Dionysos
                                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                          • Model: A1707
                                          • 15-inch, Mid 2017
                                          • 3.1 GHz Core i7
                                          • 16 GB RAM
                                          • Radeon Pro 560
                                          • 1 TB SSD
                                          • Board number: 820-00928-A
                                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                          Thanks in advance!
                                          Greetings from Germany...
                                          09-16-2025, 06:43 AM
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • jesi
                                          MacBook Pro 820-00281-A A1707 macbook
                                          by jesi
                                          hi all techs
                                          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                                          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                                          update:
                                          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                                          08-23-2025, 02:35 PM
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
