Hello, I have a Zenbook UX433. (No schematic nor boardview bur I have another same model, in working state tp compare).
It is dead : no light, nothing. And when I press power button : nothing. 19v is OK. I checked charging IC (battery removed) and the chip match ok but 3 flags are differents :
ACDET (pin6) UX433 good : 2.66v, UX433 dead : 3.1v
PROCHOT (pin10) – UX433 good : 5v, UX433 dead : 0v
TB_STAT (pin16) – UX433 good : 3.2v, UX433 dead : 0v
Do you know if it's bad or not pls ? (See below, the details of these flags)
I checked 3.3v-5v chip. It seams good. And I found 2 coils : with 3.3v and 5v (5.15v). So good.
But at the pins of BIOS chip, I can't find 3.3v, I found 3.1v (or lower, I can't remember). On the other working motherboard, I have 3.3v.
I wanted to check the continuity between the 3.3v bios pin and the provider
(coil or 3.3-5v chip). Because the 3.3v start but don't reach the bios pin, but that don't work. I thought it was just a wire between, but no. Not a good method.
What can I do after pls ?
On the datasheet of charging IC :
ACDET Adapter detection input. Program adapter valid input threshold by connecting a resistor divider from adapter
input to ACDET pin to GND pin. When ACDET pin is above 0.6 V and VCC is above UVLO, REGN LDO is
present, ACOK comparator, input current buffer (IADP), discharge current buffer (IDCHG), independent
comparator, and power monitor buffer (PMON) can be enabled with SMBus. When ACDET is above 2.4V, and
VCC is above SRN but below ACOV, ACOK goes HIGH
PROCHOT Active low, open-drain output of the processor hot indicator. The charger IC monitors events like adapter current,
battery discharge current. After any event in the PROCHOT profile is triggered, a minimum 10-ms pulse is
asserted.
TB_STAT Active low, open-drain output for hybrid power boost mode indication. It is pulled low when the IC is operating in
boost mode. Otherwise, it is pulled high. Connect a 10-kΩ pullup resistor from TB_STAT pin to the pullup supply
rail.
asserted.
rail.
