Hp g6 DAR33HMB6AO REV:A
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I have here hp g6 uma version DAR33HMB6AO REV:A laptop. the problem is cannot power on, Ive checked voltages NBSWON1# missing on PIN19 on u14 and on cn7 power button connector no 3.3v on pin4 and same with cap c59 connected to it, upon checking,Ive notice resistor R442 only have 2.7k supposed to have 10k, so ive replaced with 10k resistor same happen,checking resistor R51,R439 AND R441 have good value.only r442 is not measured 10k, anyone can help this please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Hp g6 laptop
    anyone can help?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: Hp g6 DAR33HMB6AO REV:A
      PU13-pin13 & 15 Voltage??
      • String2016
        • Nov 2015
        • 2238
        • philippines
        pin 13 12v pin15 3v
        • String2016
          • Nov 2015
          • 2238
          • philippines
          anyone can help on this please
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            You have EC_PWROK/RSMRST#/LIDSW#/?? +3VPCU_EC is present on L52? Bios flashed?
            • String2016
              • Nov 2015
              • 2238
              • philippines
              EC_PWROK present 3.3v on u13 RSMRST# is present on U14 +3vpcu_ec is present on L52 and c676 cap, already done flash bios that i got here in this forum
              • String2016
                • Nov 2015
                • 2238
                • philippines
                i flash with this https://www.badcaps.net/forum/showth...ht=DAR33HMB6A0
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  I noticed R442 measure 8k dropping to 2.8k, already tried changing with 10k resistor but still it drops to 2.8k
                  • reformatt
                    • Feb 2020
                    • 1410
                    R442 is only a pull up so value isn't overly important. You should have 3.3V on the power switch, shorting to ground when pressed. This logic change should be visible on the EC at pin 19. If you don't have 3.3V, check with P7 disconnected and check voltage across C59 and pin 19 of the EC.
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      no voltage on pin19 of u14 ec and no voltage on C59
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        ON CN7 no voltage on pin4 pin3 have 3.3
                        • reformatt
                          • Feb 2020
                          • 1410
                          Confirm you have +3.3PCU voltage on one side of R442, and check voltage other side. If it's low, and P7 is disconnected, it's either being pulled down by C59 or the EC. Also check continuity from R442 to pin 19 of the EC.
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            Done checking +3v3pcpu voltage on R442 one side have 3.3v other side has 0.400v,check pin 19 on ec beeping on R442 one side which has 3.3v, tried check R59 no short , and tried removiing R59 and check R442 still form 10k drop to 3k something is pulling down the resistor
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              anyone can help
                              • reformatt
                                • Feb 2020
                                • 1410
                                Barring some kind of track damage, it seems pin 19 of the EC is pulling it down. It's not clear which EC you have, as block view is a KB3930 whereas on pg 30 its a KB3940. I don't believe the latter needs programming.
                                Try replacing the EC is the next step.
                                • jinu_j
                                  by jinu_j
                                  Hi
                                  05-03-2025, 10:51 PM
                                • mikey5791
                                  by mikey5791
                                  Hi to all forum members,
                                  12-26-2024, 04:55 AM
                                • MidnightRoller
                                  Can a resistor lose resistance after hot air?
                                  by MidnightRoller
                                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                  02-02-2022, 11:46 PM
                                • artvandalai
                                  What resistor ohm will work better to repair this waterpik?
                                  by artvandalai
                                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                  01-05-2025, 04:10 PM
                                • chth96
                                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                  by chth96
                                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                  Since then, This AC/DC adaptor have been out of order.
                                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                  And Is there any possibility that it will suddenly explode as well as to be out...
                                  12-03-2023, 04:40 AM
