hp 255 g7 .I found 2.5v on the RAM memory
  • farag
    • Sep 2019
    • 25
    • Libya
    hp 255 g7
    Motherboard
    FPP55 LA-G07JP
    Rev;2.0
    2019-04-19
    When changing the RAM memory, the problem started.
    The ram has been changed
    I shipped the bios
    Nothing happened
    Physimeter detection
    There are1.2v and 2,5 v on the RAM memory
    Anyone have any thoughts on what happened?
  • farag
    • Sep 2019
    • 25
    • Libya
    Re: hp 255 g7 .I found 2.5v on the RAM memory
    Sorry, forgot to mention the problem
    The device is working but there is no display.
    There are 5 flashes on cap lock
    • reformatt
      • Feb 2020
      • 1514
      That's normal. DDR4 uses both 1.2V (VDDQ) and 2.5V (VPP) supplies. Look up the LED codes for HP to determine your error. 5 flashes is either 2,3 or 3,2 codes I'd say so look up the codes.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Consumption on dc supply
        01.With ram
        02.Without ram
        DRAMRST# present??
        • farag
          • Sep 2019
          • 25
          • Libya
          I got this ((:3.2
          Hardware
          The embedded controller times out waiting for BIOS to return from memory initialization.
          Reseat the memory. See the section Reseating memory modules in a notebook for more information.
          If reseating the memory does not resolve the problem, try replacing the memory modules. You might also consider contacting support for repair due to ((a possible RAM or system board failure.
          Changing the memory with a new unit did not change anything
          • farag
            • Sep 2019
            • 25
            • Libya
            01.With ram
            02.Without ram
            DRAMRST# present??
            same values: 0.57A , 0.57A
            • reformatt
              • Feb 2020
              • 1514
              I had this on an Elitebook 850 G3. Apparently the fault was intermittent leading up to it, and the RAM was certainly ok. Fault was regardless of slot used and the slots appeared physically ok too (sometimes you get bug shit on a few pins that can cause issues). As I don't have schematics for that one, the board has ended up a donor.
              • farag
                • Sep 2019
                • 25
                • Libya
                Thanks for your time
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  If consumption with/without ram is same, system is not reading ram. This can happen due to many reasons. Following should be checked.
                  01.Flash known good bios with clean me.
                  02.Check Ram IC Requirement
                  03.Check ram slot under microscope.
                  04.If the ram is onboard, it could be bad.Try disabling it.
                  05.could be pch fault.
                  • farag
                    • Sep 2019
                    • 25
                    • Libya
                    Thank you very much
                    I will try this
                      Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:21 AM
                    • kokodin
                      memory mod for amd radeon r7 260x
                      by kokodin
                      Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
                      I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
                      In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
                      03-28-2024, 03:48 PM
                      Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                      This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                      Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                      07-07-2024, 02:34 PM
                    • eccerr0r
                      old X58 triple channel board... memtest86 memory speed?
                      by eccerr0r
                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                      06-28-2025, 09:06 AM
