LA-B231P uma
  • sadik35
    • Mar 2016
    • 17
    • turkey
    LA-B231P uma
    Please help me
    LA-B231P UMA
    Picture resistor
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LA-B231P uma
    Shift R693 to R692. I dont have pic. If nothing is labelled on mb, its very difficult to trace the resistor.
    • sadik35
      • Mar 2016
      • 17
      • turkey
      Re: LA-B231P uma
      there is no trick i can't find the resistor on the motherboard
      • mon2
        • 14512
        Re: LA-B231P uma
        https://www.badcaps.net/forum/showthread.php?t=91973
        From a Russian website..
        You only need to move one resistor and remove the PL1201 coil
        • sadik35
          • Mar 2016
          • 17
          • turkey
          Re: LA-B231P uma
          R693 to r692
          where on the motherboard
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
