Lenovo ideapad Y510P not power on .
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello my friends.
    I have this ideapad Y510P not power on , consumption = 0.027 amp.
    Power sequence Page 67 , all steps are ok until n6 = NO SLP_S3#/
    SLP_S4# / PM_SLP_S5# /SLP_A#.
    Conclusion Faulty PCH or i must verify other voltages ..how to be sure that my issue is PCH.
    Thank you
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo ideapad Y510P not power on .
    So you mean its not triggering at all??Or you mean its trigerring without display??
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Hello my friend..at first 0.001 amp when power button trigger 0.027 amp
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The deflection in consumption is indicative of RTC Fault(very likely but may be other reason). So do check RTC requirement thoroughly and not just RTCRST#/SRTCRST#. BATLOW signal checked?? Its required for PCH to function properly.
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Hello my friend , sorry to be late , i take the voltages that you asking for , i think all is normal .
          SM_INTRUDER = RH149 = 2.818v /2.58v ( voltages from 2 pads of resistance )
          PCH_INTVRMEN = RH150 = 2.820v /2.739v ( voltages from 2 pads of resistance )
          PCH_SRTCRST = JME1 = 2.816v
          PCH_SRTCRST = JCMOS2 = 2.815v
          BATLOW = RH246 = 3.317v / 3.314v ( voltages from 2 pads of resistance )
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Hmm... All measurements seems good . Perhaps a dead PCH. maybe others can also advise.
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Ok thank you , have 2 questions :
              1 * You don't have a doubt for Y2 and Y3 !
              2 * RTC section must be check for many label ; how about Asus !
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I dont doubt Y2/Y3 after observing the consumption on dc supply. Crystal/clock comes much later into play to help generate Vcore. So ruled out.
                RTC-just put these keywords in schematic and check each and every point.
                • Dr.d
                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                  by Dr.d
                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                  04-05-2024, 11:48 AM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • gleniu
                  Lenovo IdeaPad Gaming 3 15ACH6 - no power
                  by gleniu
                  Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
                  10-27-2025, 01:13 PM
                • rabsonnjala
                  LENOVO IDEAPAD 100 works only on bench power supply
                  by rabsonnjala
                  Hie I have a Lenovo laptop
                  Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                  it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                  below are my readings
                  with the original charger only
                  JBATT1
                  PIN1 0.22V
                  PIN2 0.22V
                  PIN3 0.45V
                  PIN4 0.45V
                  PIN5 O.43V
                  PIN6 0V
                  PIN7 GND
                  PIN8...
                  11-20-2021, 08:32 AM
                • acata
                  Lenovo Ideapad slim 3 not power on
                  by acata
                  Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
                  And the consumer asked for reinstalling OS.
                  I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
                  Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
                  Check the main power rail for 20v input ok
                  No amper input from Power supply 0.013a
                  Mosfet PQ201 20v and 26v ok.
                  3.3v exist
                  1,8v exist
                  5v exist
                  12v from baterai exist....
                  09-30-2024, 09:42 PM
