MacBook Air a1466 820-3437 no CPU VCOR
  • ACS-Repair
    • Feb 2021
    • 204
    I have an 820-3437 board that I've been working on for a while. I resolved a problem with the ALL_SYS_PWRGD and the board comes alive with all the normal S0 rails. There is no PPVCC_S0_CPU (actually 0.06v). The CPU doesn't appear to be shorted and there re no cracks on the surface.
    Other threads speak of PTL_RESET_L, which in my case is 0v. This signal comes from the processor and I don't understand what could be missing to stop it.
    I did an SMC reset and the LED on the adapter changed from orange to green to orange again which confirms it responded.
    I would appreciate it if anyone has any experience with a problem like this.
  • reassor
    • Apr 2021
    • 181
    • Poland
    Re: MacBook Air a1466 820-3437 no CPU VCOR
    https://www.badcaps.net/forum/showthread.php?t=89867
    • ACS-Repair
      • Feb 2021
      • 204
      Thanks, I looked at this prior to posting. My case is different where I don't have the CPU VCORE.
      About an hour after I posted I realized that the PTL_RESET_L should not be present if the CPU is not powered. I'll need to look elsewhere I think.
      • ACS-Repair
        • Feb 2021
        • 204
        I see that there is no CPU_VR_EN. Will require further investigation.
        • ACS-Repair
          • Feb 2021
          • 204
          Just an update to this... I finally got this board working, although I thought I never would.
          In the end I found that CPU_VCCST_PWRGD was at 0.04v. The inputs on U1930 were correct and I could not understand why the signal was low. By accident I touched the probe while measuring pin 4 and the voltage jumped to 0.9v. This was a water damaged board so I decided to touch up the solder joints on R1931 an C1930. That solved the problem.
          I now have the signals and the computer is up and running. Thanks to all of those that viewed and contributed.
          • cruiser_
            • Nov 2019
            • 124
            • Ireland
            wow, @ACS-Repair, kudos for persistence! Does that not fell great when a 'goner' is brought back to life
            • ACS-Repair
              • Feb 2021
              • 204
              Yes, cruiser it does, although lately it doesn't alway start up to S0 state (a new problem). With the corrosion I'm going to go back and look at ALL_SYS_PWRGD at the point where it doesn't start. lucky for me this is a personal board and challenge. The learning experience has been great.
              • ACS-Repair
                • Feb 2021
                • 204
                Sorry @cruiser for not prefixing the '@' to your name.
                I believe I was able to resolve the latest problem after discovering intermittant connectivity between R8165(2) and R8167(2). Everything looked clean but I went ahead and placed a jumper between these points. the computer has been running flawlessly for the last couple of days since doing this. It just shows that you need to check everything. Hopefully this experience can help someone.
                • jheunne
                  A1466 macbook no boot green to orange light help
                  by jheunne
                  i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                  in first image there is 0v out for lcd
                  https://ibb.co/5XppmpkH
                  in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                  https://ibb.co/fdJkbJs8
                  06-10-2025, 10:52 PM
                • joeoffice12
                  MacBook Air (2017, A1466, No power/orange-green light on)
                  by joeoffice12
                  I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
                  Some voltages:
                  PPBUS_G3H - 8.5V
                  SMC_PM_G2_EN - 3.42V
                  PP3V3_S5 - 3.32V
                  PP3V42_G3H - 3.42V
                  PPDCIN_G3H - 15.18V
                  PP5V_S5 - 5.04V
                  PP3V3_S5_REG_R...
                  12-15-2023, 04:00 PM
                • GB1999
                  Macbook Air a1466 820-00165-a (No power , have orange light)
                  by GB1999
                  Hi there i have a Macbook Air A1466 board number 820-00165-A. No power, and has Orange light when plug in to charger. SMC is working and the Fuse is good. Found a Short and removed. But still there is short on mosfet. The short leading to Capacitors near Processor.
                  - 2 Mosfet Near The Processor Is Shorted. (Already Tried Injecting 1V, draining 0.07A) Unable to shop the shorted area. Marked Blue.
                  - Already Checked Big Capacitor below the processor. (Good Capacitor) Marked Blue.
                  - Found a short and solved the issue. ( Red marked Big Cap)
                  Anyone...
                  04-09-2023, 12:24 PM
                • psdavid65
                  Macbook Air A1466 820-3437-B Booting Problem
                  by psdavid65
                  I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                  06-20-2024, 12:27 AM
                • echothegamer
                  Macbook A1466 dies when charger disconnected
                  by echothegamer
                  Hello all,
                  Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                  Details:
                  Macbook 13' A1466
                  Board (820-3209-A)
                  Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                  Pictures below of Boardview and schematic...
                  I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                  It's an older model and it is very likely that battery has become...
                  10-28-2023, 12:00 PM
