Lenovo G40-30 NM-A311 will not stay ON with Ram inserted
  • Zibbo
    • Mar 2017
    • 202
    • Zimbabwe
    Hi, I have two Lenovo G40-30 motherboards NM-A311 with same issue. Turns on for for only 5 seconds and shuts down when Ram is inserted in the slot. It however stays ON without Ram.
    These voltages are present with and without ram:
    3VALW/5VALW present
    1.0VALW present
    VCORE 0.98V present
    1.35V ram supply present
    VTT 0.675V present
    Ram SCL and CLK 3.3v Present
    I have inspected the RAM slot under microscope and it is OK, I have flashed the main BIOS.
    What else should I check? TIA
  • lapfix
    • Mar 2020
    • 2723
    • my workshop
    Re: Lenovo G40-30 NM-A311 will not stay ON with Ram inserted
    Ue1 = Pin 72 = Adapte ID
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Most of the times its bad SIO.
      • Zibbo
        • Mar 2017
        • 202
        • Zimbabwe
        3.3v
        • Zibbo
          • Mar 2017
          • 202
          • Zimbabwe
          Thank you, I will try to replace the SIO and report back
          • lapfix
            • Mar 2020
            • 2723
            • my workshop
            ADAPTER_ID shouln't be 3.3v ,i suggest to verify this voltage before trying changing I/O...Try on another power supply.
            • Zibbo
              • Mar 2017
              • 202
              • Zimbabwe
              It was indeed a bad SIO. I replaced it and now the motherboard is working fine! Thank you very much
              • Zibbo
                • Mar 2017
                • 202
                • Zimbabwe
                What voltage should I expect on ADAPTER_ID?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Good to know you fixed it
                  • valente222
                    HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                    by valente222
                    I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                    there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                    n, please identify.
                    330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                    SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                    I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                    06-27-2024, 06:11 PM
                  • air_chair256
                    Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                    by air_chair256
                    I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                    Tried to reball RAM 1,2,3,4
                    Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                    02-13-2024, 06:00 AM
                  • javieromex
                    Dell G15 5511 LA-K452P won't turn on
                    by javieromex
                    Hello, any help will be apprecited!
                    • Model: Dell G15 5511
                    • MB: LA-K452P
                    • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                    • Customer reported it was turned off and left plugged in during the night and thats it...
                    • No signs of liquid damage or burned components.
                    Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                    I have checked so far:
                    04-17-2025, 12:44 PM
                  • Prott
                    Surface Pro 7 - SLP_S4 present, then gone
                    by Prott
                    Hello fellow Badcappers,
                    I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
                    Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
                    12-03-2023, 06:11 PM
                  • lapfix
                    Lenovo IdeaPad 3 NM-C961.no display
                    by lapfix
                    Hello everyone.
                    lap and motherboard : IdeaPad 3-15IGL05 Laptop - Type 81WQ
                    NM-C961.
                    Behaviour : connect charger it power on automatically ,reach 0.170 amp than down to 0.74 amp...no display.
                    with battery connected it reach 980 amp than 870 ...no display
                    No short ; no corrision no intervention before.
                    Try 2 differents bios versions same behaviour.
                    Some measuremets :
                    PL 1600 = 5valw present
                    pl 1100 = 3 vlalw present
                    pl 100 = 0.221 v without battery and when battery connected 7.8 volt
                    pl 6602 = 1.2 v
                    pl 6603 = 1.056v...
                    05-29-2025, 05:01 AM
