I have a Toshiba P745 PBQAA LA-7101P Rev 1.0. Laptop has power issues. First it refused to power on with battery power, even though it would charge battery. But after removing the battery it was working correctly. Now after taking laptop apart and cleaning board, it refuses to turn on with or without battery, when power switch is pressed, the power light will turn on for 3-5 seconds and it will turn off. At this time there is no fan spin & no display. I believe there is partial short on 3v line, getting a low resistance (less than 100 ohms) on the 3v power supply coil.
					Toshiba P745 won't power on
 Assuming...7 Photos
			by PantherDaveHi all!
			by GLISITHi all,
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by ju123Hi guys,
 So, I've been racking my brains on this one.
 I have a Satellite C50-A which I'm repairing for a friend.
 I recently replaced the main board due to failure.
 Following this, absolutely everything works perfectly, except for the fact it won't power down.
 Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
- Loading...
