Lenovo Y530 (NM-B701 rev1)
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Hello everyone!
    I got a faulty Lenovo Legion 5 Y530-15ICH (MB: NM-B701 rev1) under my hands and I simply cannot troubleshoot the cause of the problem.
    The symptoms:
    The notebook only turns on If I leave it turned off (With only the battery and cmos bat. plugged in) for a while (1h+). And I it does turn on and succesfully boots to windows, it does work for a while until it looses power (notebook shuts off completly) or I turn off by clicking shut down in Windows.
    If I turn it off I have to wait again until it can start up again. Otherwise the pwr comes up for a few seconds, without display (altough sometimes I see the Legion logo apper without backlight.) and it turns itself off.
    What I measured:
    - I tested the charger, charger port, battery, the 5V,3V if they are present. Everything present.
    - I also measured UE1 controller chips (IT18226E) 77,3,21,83,85,128,108,76,90,97,123,110,111 pins too, If anything missing but looks fine to me.
    -Also, I checked on the BIOS chip if it getting voltage, because I had quite a few times when the system crashed and turned off when I entered the BIOS/Novo menu.
    - The C55 capacitor next to the USB (EAY28 6.3V) won't drain power even if the batt/AC disconnected. I tried to discarge it by holding the pwr button for 30 sec but nothing happens. It's still measures between 0.20-0.30V and slowly depleting.
    Things I found:
    - As I mentioned above, If I leave it off for a while it will most likely start up normally until the next crash/restart. Plugging in the AC charger seems to stopping this to work however.
    - The other thing is If I connect the AC charger while the CMOS battery in plugged in, the PWR button LED will flash for 1s. But If I unplug the charger and reinsert it it will not flash whatsoever UNTIL I unplug the CMOS battery. The PWR LED flashes every time If the CMOS battery is not connected.
    It's seems like something causing a shortage maybe and It's stays this way until the problematic component discharges completely or something. I'm just making theories.
    I hope I provided enough info and thank you very much for your help in advantage!
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Re: Lenovo Y530 (NM-B701 rev1)
    UPDATE #1
    Since then I ordered a can of isoporpyl alcohol for cleaning, maybe some miniscule oxidation causing the issue somewhere.
    While I waiting for the stuff to arrive, I found out that If the CMOS battery is not plugged in, the CPU doesn't produce any heat, but if the CMOS battey is present the CPU gets blazing hot to the touch after pressing the power button.
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
