Lenovo 330s-15ikb ram disable onboard
  • mon2
    • Dec 2019
    • 14368
    Onboard ram disable laptop motherboard #repairing #bios #engineering (youtube.com)
    Also check this one:
    https://youtu.be/fhAfgS9KNNs
    and
    How to disable onboard RAM Memory on your laptop - Coming on with no picture? This can be a reason (youtube.com)
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Originally posted by ktmmotocross
      how?
      01.Open your bios dump in hex editor. Press Ctrl+F,search for 2311 in Hex value,press search all.
      02.Go to bottom of the search window and you'll see 13 similar looking rows.
      03.Double Click on the last row among similar looking rows
      04.Click at the beginning of OFFSET 23 11,press Ctrl+E,select length 200 and click ok.
      05.Note down the end offset(DE2288) and right click on it,select copy offset.
      06.Now double click on the 1st similar looking rows.
      07.Click at the beginning of offset 2311,press Ctrl+E, and put the end offset (DE2288) and press ok.
      08.Click "fFill selection" and just press ok and save the file. Flash this Bios
      That will zero fill all the onbaord ram data.
      I hope i've detailed the process to the best of my abilities as i see lot of members are struggling with this issue.
      Hope this will help a lot of members.
      PS: The process is 100% correct as i myself has tested it. Be careful while going thru all the steps. may take a couple of attempts to get success in the beginning.
      DONT EXPECT ANY SUPPORT FROM ME FOR EDITING YOUR BIOS.
      • ktmmotocross
        ktmmotocross commented
        Editing a comment
        its for all lenovos or for all laptops ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      mon2, its useless to watch those Youtube videos as they dont reveal the process and rather see a business oppurtunity in editing the bios. Unfortunate but bitter truth.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The process of onboard ram disable is same for all brands. Have tested this method on Lenovo and Asus so far and it worked in both the cases.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3609
          • slovakia
          it will be great if u make some example guide. best on this bios example of mine 😁
          i found 81 hits for 2311 but cannot find that "13 simmilar looking rows" over last 2311
            SMDFlea commented
            Editing a comment
            You wanna post a bios request you know where it goes,and its not here !!!!!!!!!!!!!!!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          #26
          @ktmmotocross,Try selecting the block 783A00-7841CF AND ZERO FILL it. Not sure whether it'll work. This bios is different in structure.
          • apostsamking
            • Dec 2017
            • 117
            • Ghana
            #27
            i managed to edit the bios by selecting the block 783a00-7841cf and filling them with zero. after flashing the laptop with the edited bios. it displays but will take like a minute for it to display. But i still see the size of the disable ram. how can i fix this.
            • apostsamking
              • Dec 2017
              • 117
              • Ghana
              #28
              ANY HELP PLS
              • McSaird
                • Oct 2022
                • 6
                • Russia
                #29
                any ideas? same problem with 330s_ast_mb (Ryzen)
                • MDSI
                  • Apr 2022
                  • 26
                  • France
                  #30
                  Originally posted by apostsamking
                  My motherboard looks different. mine is 330s_KBL_MB_V09 REV MP. PICTURE ATTACHED. can any one help be disable the onboard ram
                  Same probleme here
                  • robante15
                    • Nov 2020
                    • 58
                    • El Salvador
                    #31
                    Hello, I have a Lenovo Ideapad 330S-15IKB [MB: 330S_KBL_MB_V06] [SN: YD04PY5P] with soldered RAM.
                    The customer reports that the computer was running, began experiencing graphical glitches, and shut down, never turning back on. When I connected it to the power supply, it showed around 350-400mA of power consumption, which remains there and never produces an image. I've measured the power supplies, and the voltages are correct. I suspect a RAM issue, which is common on these computers.
                    I need to disable them. Reviewing the schematic, there's no resistor configuration that would disable them.
                    I also know that on other models, they can be disabled by editing the BIOS with the SPD Removal Tool, but when I analyze my machine's BIOS, the tool doesn't detect any SPD information.
                    So I don't know how to disable the soldered memory. Does anyone have any ideas on how to solve this problem?
                    I've attached the schematic and a backup of my BIOS just in case.
                      • 21209
                      Thread merged.
                      Please post links to the schematic & boardview, they are already posted in the "Schematic requests ONLY!" forum . If you want someone to have a look at your bios post it in the bios requests forum https://www.badcaps.net/forum/troubl...-requests-only
                      • alfredposadas09
                        • Aug 2020
                        • 343
                        • Philippines
                        #33
                        Can you pls help me with that?
                        upload bios i will help you
