Hp probook 6570b only external display
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    I have hp probook 6570b that has only external display but nothing on the laptop screen.
    Any guidance please.
    (P/N: 010172N00-575-G
    CASPER-UMA_CR_HPB
    MV_MB_V1)
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Re: Hp probook 6570b only external display
    Any tip from axperts plz
    • mon2
      • Dec 2019
      • 14663
      Check if the LCD display is working by applying a flashlight around the front side of the display. Can you see any graphics on the LCD display? If yes, then the backlight is an issue.
      • usyusy
        • Sep 2021
        • 171
        • Pakistan
        no sir, same situation
        • mon2
          • Dec 2019
          • 14663
          Can you link any schematics for this logic board?
          Perhaps the lcd display is damaged? What is the history of the laptop?
          Any liquid damage? Check the lvds cable, connector, be sure the contacts are clean on the display cable.
          Is the backlight working?
          Suspecting there is a mux that routes the display traffic to either the external hdmi port or to the local display. Schematics will be helpful.
          • Conste
            • Oct 2018
            • 235
            Integrated HD4000 or AMD graphics?
            If AMD graphics probably there is the problem
            • usyusy
              • Sep 2021
              • 171
              • Pakistan
              Sir lcd was changed with working one, lvds was also replaced, but same result,
              I could not found its schematic, so unable to check lvds connector pin volts
              • usyusy
                • Sep 2021
                • 171
                • Pakistan
                Sir Intel HD graphics
                • mon2
                  • Dec 2019
                  • 14663
                  Are there any labels or markings on the display?
                  Post all details here. Perhaps there is a public datasheet that will help to determine the voltages on the display connector.
                  • usyusy
                    • Sep 2021
                    • 171
                    • Pakistan
                    in the start, i saw CMOS battery error
                    but as i was using charger, so in neglect it
                    other pics are as follow.
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Hi here shematic if it is the right one.
                      Good luck
                      Regards
                      • usyusy
                        • Sep 2021
                        • 171
                        • Pakistan
                        Good luck
                        Regards
                        Thank you sir, its the one
                        • usyusy
                          • Sep 2021
                          • 171
                          • Pakistan
                          Lvds connector pins and surroundings components were checked, some have values others are not, the findings are attached in pic along with schematic pic.,., any guidance please
                          • Stevedb
                            Stevedb
                            • Feb 2018
                            • 624
                            • Belgium
                            Hi i would look to the lidswitch first. Test the lidswitch. You need 3,3v. Also measure the resistance tobground where you got 0v and share it here.
                            Good luck
                            Regards Steve
                            • usyusy
                              • Sep 2021
                              • 171
                              • Pakistan
                              Good luck
                              Regards Steve
                              sir i dont know what happened, but the display has come. the values of
                              >> lid_switch is now around 3.18V on D33 diode, earlier it was 0.03V
                              >> on IO Pin No. 64, is also 3.18V earlier it was 0.03V
                              >> as per schematic, the lid switch value on the Hall Switch IC (U1002-as shown in attached pic) is also 3.18 V
                              For knowledge seeking, what can be the reason if lidswitch volt is missing.
                              • Stevedb
                                Stevedb
                                • Feb 2018
                                • 624
                                • Belgium
                                Maybe cold solder joints somewhere. Try ti tenew solder joints on the circuit.
                                • M4n0l0307
                                  • Nov 2020
                                  • 171
                                  • Republica Checa
                                  Good luck
                                  Regards
                                  Thank Friend !
                                  • Stantechs
                                    • May 2011
                                    • 29
                                    • Nigeria
                                    Good luck
                                    Regards
                                    Thank you Steve
