820-01958 chime, blank display and restart
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    i have macbook air A2179 820-01958 that some water damage around:
    - CC714 and CC715 (PP5V_G3S)
    - C6523 (PPVOUT_S0_KBDBKLT_R)
    - F3000 (PPDCIN_G3H and PPHV_INT_X_G3H)
    after clean all those components. i tried to turn it on bust have blank display and always restart (based on chimes)
    here are the measurements:
    - PPBUS_G3H = 12.58V
    - PPBUS_HS_CPU = 12.58V
    - PPDCIN_G3H = 19.98V
    - PP5V_G3S = 5V
    - PP5V_S5_LDO = 5V
    - PP3V3_G3H_RTC = 3.271V
    - PP3V3_G3H = 3.271V
    - PP1V8_G3S = 1.795V
    - PPVCC_S0_CPU = 1.6V
    - PP1V1_S3 = 1.095V
    - PP0V6_S3 = 1.01V
    N.B CPU is very hot
    what could be wrong?
    any help would be appreciated.
    thanks before
  • mon2
    • Dec 2019
    • 14677
    Re: 820-01958 chime, blank display and restart
    hi.
    1) do not power on as PP0V6_S3 = 1.01V is incorrect and could cause damage. This rail should be 0V6.
    2) See attached. Inspect the parts in the red box. Each value should be correct to properly allow for the buck regulator to regulate to 0V6. Based on the measured value, the FB resistor(s) are not the proper value.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      Originally posted by mon2
      hi.
      i checked value for:
      R8150 9.8ohm
      R8151 90.8ohm
      R8152 2K ohm
      so i changed R8152 but the value still 2K ohm...if P0V6_S3_FB is shorted that means the value for R8151 shouldnt be normal right?
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        i just found out that PP1V1_S3 is shorted to ground
        • M4n0l0307
          • Nov 2020
          • 171
          • Republica Checa
          hi.
          Thank you friend !
          • shouri
            Dell latitude e5490 auto restart
            by shouri
            Hi guys, can someone help me?
            I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
            Board model is dm70 la-f401p rev:1.0 2017-09-20.
            At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
            After a few days test, is seems ok.
            Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
            12-10-2024, 09:27 PM
          • hasel17
            CH341a can erase and read but can't write and blank check
            by hasel17
            So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
            Code:
            Checking for blank...
            (Press
            10-26-2023, 06:20 AM
          • kotel studios
            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
            by kotel studios
            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
            State I got it in:
            Squealing from the PSU
            After logo I get a blank screen
            After 10 seconds of having a blank display w/ backlight the TV dies
            Give it 7-10ish seconds again and it starts to bootloop.
            What I did so far:
            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
            Checked all voltage rails:
            5VSB - 4.8V
            AMP+13V - 14.4V
            13V - 12.98V (in manual 12V)...
            09-21-2025, 02:00 AM
          • RetroComputingGrotto
            Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
            by RetroComputingGrotto
            I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
            I've uploaded a video of it happening on YouTube:
            I've taken the monitor...
            01-11-2024, 05:37 AM
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
