A1466 with no backlight but boots (820-00165)
  • mon2
    • Dec 2019
    • 14679
    Hi. Having some fun with a 820-00165 logic board (liquid damaged) that is booting (no ssd installed) but is missing a backlight.
    Corrosion near D7701 and nearby inductor / caps for the backlight area. Cleaned up with alcohol but always see 8v5 for the backlight.
    Replaced the TI LP8550 3 times and each time, was dancing yet no high LED voltage @ cathode of D7701.
    Came across the logiwiki page for the A1466 and the details of the via that is on the same side is gold. This tiny via corroded away and no longer supplied the feedback voltage to ball A5 of the LP8550. After many attempts to solder a bridge to D7701, ended up using a single strand of wire from an old IDE cable and gently inserted to the corner A5 ball.
    Then bridged to the bottom side vias that offer the same rail.
    This worked! Now have 23v9 volts (PPHV_S0SW_LCDBKLT) on the cathode of D7701 -> same voltage on the LVDS cable (pins 3 & 4). All good.
    Except LCD panel is still dark. Tested with another LCD panel - same issue and remains dark.
    Using a flashlight on the back of the display, can see the flashing folder (since SSD is not installed). Have fan spin.
    Diode values for
    R7717, R7718, R7719, R7720, R7721 @ 0v6 = matches the boardview values
    R7722 = 0v4 ; could this be an issue ??
    Any ideas on what could be wrong here?
    Perhaps reflow U7701 again ?
  • mon2
    • Dec 2019
    • 14679
    Re: A1466 with no backlight but boots (820-00165)
    Update - removed the LCD and found 5v0 @ R7722 only.
    Suspecting that this is (was) due to a short under the LP8550. Reflowed the IC again and made it do the wah-watusi. So much fun while trying to retain the single strand of wire @ A5 to complete the FB circuit. Keep this exercise in mind for a night with the wife & kids.
    Now lost the 25v boost but R7722 is like the other LED return lines with diode reading @ 0v6.
    Will replace this dreaded IC tomorrow when rested.
    • ACS-Repair
      • Feb 2021
      • 204
      I had this once on an older MacBook Air, maybe 2012 model. I also had 24 volts on the backlight but it was not enough for the backlight to be visible. I found with the help of others that I could get full brightness simply by doing a PRAM reset. The screen immediately brightened up. Unfortunately, I think you had this working but now you have a new problem to resolve first. I also did a hair wire to pin A5 on the LED backlight driver (00165) and it was tricky to apply without touching other pins. I think you're almost there.
      • N3Star
        ASRock X99 Extreme4 boots only on cold boot
        by N3Star
        The motherboard in question boots only on cold boot - if I cut power to the PSU it will boot fine, but as soon as I reboot from Windows or even short reset pins it goes into bootloop - 1 second on, a few off and so on.
        Initially the board arrived to me broken - bad PCH, after replacing it it worked for a while. I suspected a bad connection, but pushing the IC down does nothing. I don't really think that the PCH is dead, since it still boots and works fine until I reboot the PC. Obviously I tried looking for something that heats up or bad caps, but nothing so far....
        10-25-2025, 02:53 PM
      • pepebmx
        ThinkPad T14 Gen 3 - Boots Only on Charger
        by pepebmx
        Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
        Laptop: Lenovo ThinkPad T14 Gen 3
        Serial No: PF-437QTG
        PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
        Extracted BIOS: Will upload tomorrow
        BIOS Password: None Issue Description:
        • Boots only on charger → Works normally when connected to AC.
        • With battery connected:
          • Fan spins at full speed, no display.
          • Not all voltages present (some missing).
        • Battery charges correctly (detected in Windows, shows percentage).
        • When battery is plugged in while in Windows:
          • Laptop shuts
        05-08-2025, 01:53 PM
      • sikocan
        MacBook Air A1466 Backlight comes on for less then 1 second.
        by sikocan
        Hi all, I'm going crazy and can't figure this one out.
        MacBook Air A1466
        Board: 820-00165
        Issue: Backlight comes on for a split second - then off. I can capture the 26V on the Oscilloscope before it disappears. Picture is fine and OS boots fine.
        I've replaced the following:
        4 Different screens
        4 U7701
        1 D7701
        1 Q7706
        1 Q7707
        I've inspected LVDS connector - it looks good.
        03-03-2023, 06:14 AM
      • psdavid65
        A1466 820-3437-B Bios Problem
        by psdavid65
        I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
        06-18-2024, 05:26 AM
      • abajor
        A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
        by abajor
        Having this very weird issue.
        The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
        I swapped with a working screen from an A2141 waiting for parts.
        The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
        The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
        04-27-2024, 01:37 PM
