Dell E5440 completely dead
  • Andreasbest
    • Aug 2014
    • 1188
    • Hellas ( Greece )
    Re: Dell E5440 completely dead
    Originally posted by Andreasbest
    Hello again.
    PL5 one side is indeed grounded but i think is normal, all rest coils are fine, no shortcircuits to ground.
    Indeed both sides are grounded, wrong measure before (probably probe needed some more pressure on lead)
    • Sephir0th
      • Oct 2020
      • 1283
      Ok. So it seems most of the parts on the supicious rail were checkd, except PQ5 and PU701, right?
      FairRepair on YouTube
      • Andreasbest
        • Aug 2014
        • 1188
        • Hellas ( Greece )
        Seems so, what do you suggest?
        • Sephir0th
          • Oct 2020
          • 1283
          Unfortunately i can't find datasheet right no for PU701, but you can at least check whether 19V reach Pin1 and of course, you can check each pin for short to GND
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            How many amps is the board taking?
            • Andreasbest
              • Aug 2014
              • 1188
              • Hellas ( Greece )
              #26
              5 6 7 14 15 & 32 are grounded
              Pin #1 receives 19.5v
              • Spider1211
                • Oct 2019
                • 532
                • Mauritius
                #27
                How many amperes? Do you have a bench power supply? If yes, set it to 19.5V and power the board from it.
                • Andreasbest
                  • Aug 2014
                  • 1188
                  • Hellas ( Greece )
                  #28
                  You mean if i apply 19v directly to DC_IN?
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    #29
                    Check where the DC adaptor connects to the motherboard. Apply power from your power supply on the DC connector pins, just make sure which is +ve and -ve first.
                    • Sephir0th
                      • Oct 2020
                      • 1283
                      PU701 Pin 6 & 15 short to GND means Main Power Rail short to GND. How could that Be missed before?
                      • Andreasbest
                        • Aug 2014
                        • 1188
                        • Hellas ( Greece )
                        #31
                        Yes i can confirm pin 6 and 15 of PU701 are both grounded.
                        What do you suggest?
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          #32
                          Do a visual check first to identify if something is physically damaged, otherwise Inject voltage on that line and see what gets hot. As always, start with 1V 1A then increase amp slowly if needed.
                          • Andreasbest
                            • Aug 2014
                            • 1188
                            • Hellas ( Greece )
                            #33
                            Did visual inspection before, totally clean mb.
                            Gonna inject voltage and report in 2 mins
                            • Sephir0th
                              • Oct 2020
                              • 1283
                              First, Share exact Résistance to GND there in Ohms Mode, Range 200 or Auto-Range to exclude a Short with a step down Circuit.
                              • Andreasbest
                                • Aug 2014
                                • 1188
                                • Hellas ( Greece )
                                #35
                                When i set it to Ω shows 20Ω not 0.
                                • Sephir0th
                                  • Oct 2020
                                  • 1283
                                  20 Ohms are probably Bad News. Now you have to Check Resistance to GND of each coil. Look for a similar value...
                                  • Andreasbest
                                    • Aug 2014
                                    • 1188
                                    • Hellas ( Greece )
                                    #37
                                    I see same value only on PL400 (both pins) all other coils have values way beyond this.
                                    • Sephir0th
                                      • Oct 2020
                                      • 1283
                                      That's fine then. So Voltage injection Like mentioned before. Pay Attention especially To PU401 and PU701.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1188
                                        • Hellas ( Greece )
                                        #39
                                        I inject voltage on pin 6 (+) and GND (-), 1v 1a and drown only 0.4A, no shortcircuit indication.
                                        • Spider1211
                                          • Oct 2019
                                          • 532
                                          • Mauritius
                                          #40
                                          They both share a common line through PR400. You could try removing PR400 to see which side is 20Ohms.
                                          I suspect it might be a faulty PU701. These are fairly easy to remove and resolder. I'd try removing it and see if the 20Ohms is still there. Or you could just inject voltage, but with 20Ohms at 1V, I doubt anything will get hot (expected 0.05A flow).
                                          • max-power
                                            Dell E6540 laptop completely dead after dssasembly
                                            by max-power
                                            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                            03-24-2025, 08:49 AM
                                          • diamon
                                            Dell Latitude 5520 completely dead
                                            by diamon
                                            I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                                            Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                                            After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                                            Have checked with a thermal camera, and there are a couple of things...
                                            03-05-2025, 02:23 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • gugutm
                                            Dell Latitude 5410 dead help please.
                                            by gugutm
                                            hi everyone,
                                            need some advice i am not professional just junior , but maybe someone could help me please
                                            i have
                                            Device : Laptop
                                            Brand : DELL
                                            Model : LATITUDE 5410
                                            Board Number: FDZ41 LA-J371P Rev:1.0
                                            i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
                                            my problem is its not turning...
                                            08-28-2025, 02:24 PM
                                          • Francesc V.
                                            Dell dockstation WD15 is dead
                                            by Francesc V.
                                            Hi:
                                            A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                            Here are the findings, followed by good pictures. :-)
                                            When pluged in, LED3 glows
                                            Measuring some voltage in the circuit.
                                            Inductors
                                            - PL202 has 5V
                                            - PL201 has 3.3V
                                            - PL300 has 1V
                                            V. Regulators
                                            - UT30 has 19v as input and 6V as output. It seems ok.
                                            - UT27 (same reference as UT30, has no input/output voltage).
                                            Thermal find...
                                            07-09-2025, 12:12 AM
