toshiba l855 - Dk10fg-6050a2491301-mb-a02 power issue
  • bembeno
    • Feb 2016
    • 313
    • egypt
    when i pluged in the power adapter i found the 3.3 & 5 volt on coils but no voltage on power button i replaced the io with a new ic but still no volt on power button
  • bembeno
    • Feb 2016
    • 313
    • egypt
    Re: toshiba l855 - Dk10fg-6050a2491301-mb-a02 power issue
    i think the new io chip shoul be programmeing
    and this is the datasheet
    • bembeno
      • Feb 2016
      • 313
      • egypt
      l850
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        NPCE885 is not programmable.
        • somazvanica
          • Sep 2021
          • 6
          • Serbia
          Hello i have problem wtih this laptop Toshiba C855 its a ...mb-03A model of mainboard and problem is laptop only wants to turn on when hi is long time... on charger i just cant turn him on normalu , i take a look on voltage
          Coil L6000 - 3.1 v
          Coil L6100 - 3.3 v
          Coil L6150 - 5.1 V
          i am not sure is it good on L6000 to have 3.1 , its on q6000 gate that voltage..
          and i didnt find shematic on ...mb-a03,.. and boardview just this a02 ,
          do someone know what can make problems like this. thx
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
          • claws77
            lenovo flex 5 14itl05 power sequence issue
            by claws77
            hi guys, my motherboard will not start no matter what
            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
            but rest nothing happens no sign of life.
            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
            i have no knowledge of motherboards ....
            10-20-2024, 02:48 PM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
          • SuperJames
            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
            by SuperJames
            This one's a weird one, and still unsolved despite it having gone back to Dell once.
            Specs
            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
            Backstory
            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
            10-23-2023, 04:09 PM
