Datalogic Memor DL 800
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi guys
    I've a Datalogic DL-Memor 800-904-416.
    It won't start. Only a red led at the right side on. It's logic board problem (I've try to replace power board and other peripherals)
    Anyone have experience on this device?
    Thanks and best regard.
    Luca
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • korben_dallas
    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
    by korben_dallas
    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
    MY QUESTION:
    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
    02-14-2024, 12:23 AM
