Datalogic Memor DL 800
+ More Options
Posts
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi guys
    I've a Datalogic DL-Memor 800-904-416.
    It won't start. Only a red led at the right side on. It's logic board problem (I've try to replace power board and other peripherals)
    Anyone have experience on this device?
    Thanks and best regard.
    Luca
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
    by ohren
    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
    The models launched in 2018 and 2019 respectively....
    09-08-2023, 05:24 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • korben_dallas
    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
    by korben_dallas
    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
    MY QUESTION:
    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
    02-14-2024, 12:23 AM
