hp 15 db0044nc error 0xc00000e9
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have this laptop with problem loading OS. It shows error 0xc00000e9.
    Without HDD, only USB with OS plugged in (WIN10) and this error appear.
    Laptop was little bit liquid damaged but board was fine, clean. I disconnect all from the board which not must be connected and problem persist.
    I run memtest and memory is OK. Please, how can I update bios on this new hp laptop via USB? On official page is manual, but I don't have BIOS update option in diagnostics after pressing F2.
    Any idea how to fix it? thanks.
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    Re: hp 15 db0044nc error 0xc00000e9
    I attached a photo. Sorry for its quality..
    • mon2
      • Dec 2019
      • 14681
      Try a different USB port; try a different USB media stick. We know from experience that not all USB thumbdrives are created equal.
      We build products for the PC industry and many of our flash programming tools are DOS based. We use the freeware RUFUS tool to apply our bootable (FreeDOS) and USB thumbdrives. You would be surprised as to how many branded drives are crap and cannot boot the FreeDOS image. Many of the Kingston brand failed.
      We know that Lexar work well on all tested platform. In chatting with USB thumbdrive manufacturers in Asia, they confirmed that Kingston used a different controller inside that raised booting issues with Rufus (and perhaps others).
      You can also test with a USB 3.0 port on your box (if available). If the USB connector is BLACK = USB 2.0 port. If the USB connector = BLUE / Purple = USB 3.0 port (recommended).
      If purchasing a USB thumbdrive, consider a USB 3.0 version.
      This is all assuming that your USB port / controller / hub on this logic board is working ok. Try other ports and post your results.
      • DeniS182
        • Jun 2014
        • 328
        • Slovakia
        thanks for answer.
        I tried another USB stick and also all ports. But nothing changed. And error appear also when HDD is connected only with W10 installed.
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          It works now. I flash bios with the programmer.. I used bios dump from official page- latest bios.. boot now normally but I need to remove text "Manufacture Programming mode is in unlock mode" and if it's possible add serial and windows key to bios. I know is some tool for this but I can' find it and I don't know how to do it.
          Can samoene help me please?
          I attached backup of my old bios F.10 , new bios F.37 and screen from bios, some photos..
          • Jovica123
            • Oct 2017
            • 84
            • N/A
            Type on youtube : "Solve Manufacture Programming Mode Is In Unlock Mode Error" and follow the steps.
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              The TV does not turn on, the standby indicator is on. All voltages are present.
              Emms is dead. Not readable, not detected.
              Replaced emmc.
              But with another dump there is no launch
              Terminal log
              UART
              AC_ON
              RPMB key is not yet programmed
              HASH1_VERSION=0x00000000 64bit
              E-B
              FDE enabled
              layout pattern onebin by SAR7,0...
              06-01-2025, 02:11 AM
            • medinfo
              Mac T2 after update(There was an error activating your device)
              by medinfo
              Macbook Pro 2019 T2
              iCloud OFF
              MDM unlocked by changing Serial Number
              worked fine but after latest update see (There was an error activating your device. Please try again).
              Erased and boot in internet recovery, same error.
              changed to original serial number (iCloud OFF & MDM ON), same error.
              tested with others serial number, same error.
              tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
              Revived and restored by Apple Configurator and same error.
              Any help ?
              12-31-2023, 02:04 PM
            • sushilachuthan
              APC UPS error P13
              by sushilachuthan
              one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
              the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
              The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
              We replaced the SCR with new device,, but the device is not power on as expected.
              Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
              09-26-2025, 09:00 AM
            • unick
              Laptop HP 850 G2 Keyboard error after Windows 11 update
              by unick
              Hello
              i have following problems on HP 850 G2 laptop and 840 G2 laptop. After win11 update 24H2 the keyboard and touchpad stop working. I delete the keyboard from device manager and restart : work. If i shut down the laptop and restart after 5 min the problem apear again: no keyboard and no touchpad active. I have used also hp driver from oficial sit but no luck. I have modified with regedit " i8042prt Start REG_DWORD with 1, but no suscces. Any ideea?
              09-15-2025, 07:47 AM
            • doivaythoiem
              LENOVO NM-E291 REV0.2 Update bios error
              by doivaythoiem
              Need help bios
              LENOVO NM-E291 REV0.2 UPDATE BIOS ERRO
              SN not found because it was deleted
              original bios...
              02-18-2025, 03:25 AM
