MacBook Air 13" A2179 ODD ISSUE
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Turns on, works, goes into internet recovery and loads up the internet recovery to get the OS ready to load. Once it gets to the end it shows the Apple logo and it flashes and then the folder shows up after that. This computer does this ALL the time now. For some odd reason it will not load the OS up in internet recovery, it downloads, gets to the end, then shows the Apple logo when it reaches the end and it turns the screen off and back on and the flashing folder is displayed.
    Anyone come across this issue?
    Also DFU mode was used to recover the computer and it works and recovers it, its just odd that it wont load the OS from internet recovery. Since this is a T2 machine I cannot load a USB installer until I get a OS installed with a user name etc.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • 14672
    Re: MacBook Air 13" A2179 ODD ISSUE
    The flashing folder means that the drive is empty or that it cannot see the drive.
    Check the voltage rails for the SSD.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Ok I’ll do that tomorrow.
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Noticed tons of flux near the U4770 area it was the SSD NAND voltage regulator. I am going to throw it in the cleaner and see if that solves the problem. Board does turn on etc. But seems to be a problem loading the internet recovery OS once it downloads it. Forces it into flashing folder mode after it downloads it.
        sigpic
        • Stephen
          MacBook Air 13" A2179 2020. 5Volts .250 amps issue
          by Stephen
          Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
          PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
          ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully...
          02-18-2025, 05:54 PM
        • yaya3gmax
          Laptop Power Issue – Works on Battery, Fails on Adapter Load
          by yaya3gmax
          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
          Symptoms:
          • Laptop works normally on a pre-charged battery.
          • Battery does not charge when adapter is connected.
          • Without battery:
            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
            • Speakers “pop” when power cut occurs indicating harsh sutdown.
            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
          08-21-2025, 07:16 AM
        • Darren Hibbert
          MacBook A2179 Audio board+Power button boardview & schematic needed
          by Darren Hibbert
          Hi.
          Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
          There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
          Many thanks. ...
          08-21-2025, 02:38 PM
        • thuygsm
          Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
          by thuygsm
          I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
          I noticed there is liquid at U3200 and U3100 and have replaced them.
          PP1V5_UPC_X_LDO_CORE : 1.575V
          PP3V3_UPC_X_LDO : 3.280V
          PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
          I have isolated R6979,
          Pin 1: 3.280V stable
          Pin 2: 0.447 (diode)
          PPBUS_G3H: 12.28V (with R6979 isolated)
          PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
          What should I do next?
          10-29-2025, 06:02 AM
        • pcbmaniac
          MacBook A1278 (3115) No PPBUS_G3H Issue
          by pcbmaniac
          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
          1. U7000 Measurements:
            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
          2. Resistors:
            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
          • If I also decide to replace the SMC, do I need to order it pre-programmed,
          12-02-2024, 04:12 PM
