IC KBC trouble
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    IC KBC trouble
    after removing the kbc ic, the laptop actually shorts 3v & 5v when connected to an adapter or battery.?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    Re: IC KBC trouble
    no
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      Re: IC KBC trouble
      that's the problem now bro, when connected to an adapter or battery, the voltage is 5v, 3v immediately shorted
      • zeroalpha
        A1706 Macbook Pro PPBUS_G3H Shorts to ground when charger connected
        by zeroalpha
        A1706 with some liquid damage. I've cleaned it but PPBUS_G3H will short to ground when its connected to the charger.
        Watch a short clip of whats happening here:
        https://youtu.be/HcegjB4fWVM
        Is there a problem with PPBUS_G3H and what should I look for?
        01-24-2023, 10:49 PM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • rob_hen
        Dell XPS 13 9370 Laptop, No power, not charging
        by rob_hen
        Hello!
        This is my first post for help, and I am quite newer to board repair, so bear with me.
        I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
        After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
        There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
        My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
        05-01-2025, 09:20 PM
      • KYBOSH
        Samsung UN55HU8550F - No picture, No sound
        by KYBOSH
        Previous owner says this unit powers on and sometime has an image and sometimes not. They attempted to replace the main board but with no success.
        TV came with the replacement mainboard as well as the original.
        When the TV turns on there is no image or sound. No response to the remote or toggle button other than the power button. The power supply's relay was clipping here and there. It did that for several seconds even after I removed the mains. I did this even with no other boards connected (only the backlight was connected at the time). Backlight looks fine but...
        01-09-2023, 02:36 PM
