A1706 Macbook Pro PPBUS_G3H Shorts to ground when charger connected
  • zeroalpha
    • Mar 2022
    A1706 with some liquid damage. I've cleaned it but PPBUS_G3H will short to ground when its connected to the charger.
    Watch a short clip of whats happening here:
    https://youtu.be/HcegjB4fWVM
    Is there a problem with PPBUS_G3H and what should I look for?
  • mon2
    • 14333
    Re: A1706 Macbook Pro PPBUS_G3H Shorts to ground when charger connected
    1) remove all power.
    2) meter in resistance mode.
    3) measure the resistance to ground of ppbus_g3h. What is the measurement?
    4) remove all power. Remove the output fuse on ppbus_g3h.
    5) measure the resistance to ground on each side of the removed fuse pcb pads. Post each measurement.
    6) power up again - with the fuse removed. What is the voltage to ground of ppbus_g3h at the producer side (ISL) of this power rail ?
    Often, a shorting cap will cause the fault you are observing. The resistance checks will confirm this case.
    Do you have an adjustable power supply?
    Can it be used to dial up a 1v0 output voltage?
    • zeroalpha
      • Mar 2022
      3) 2 MΩ
      5) Removed F7000.
      Pin 2 (PPBus_3GH) = 2 MΩ
      Pin 1 (PPVBAT_3GH_CHGR_REG) = O.L
      6)
      Pin 2 (PPBus_3GH) = 1.1v
      Pin 1 (PPVBAT_3GH_CHGR_REG) = 20v
      With the fuse removed PPBus_3GH no longer goes short to ground either
      Yes i have an adjustable power supply
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
      • baglaivlad
        A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
        by baglaivlad
        Hello everybody!
        Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
        After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
        11-20-2024, 08:14 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • Egidio85
        lenovo V145-15AST LA-G241P shorts out the battery charger
        by Egidio85
        hi, I'm writing about a strange problem on levono V145-15AST with LA-G241P motherboard.
        The PC turns on and works fine. the battery charges for 15-20 minutes and then the battery charger goes into protection mode. Already tried another battery charger.
        the charging LED flashes 3 red times cyclically when it drops below 20% and is being charged. when it reaches above 20% the charge LED turns solid white but turns off for an instant every 4-5 seconds.
        Charging chip is intersil 88739A
        I noticed that the components circled in the photo heat up quite a bit when charging....
        10-11-2023, 04:35 AM
