Lenovo ideapad 310-15abr CG516 NMA741 only power on with power supply connected,
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    does not connect only in battery mode, with power supply works correctly and charges the battery. battety is ok.
    if i remove the power supply, it switches off after about 1 second.
    if i cheat the bq24780 when injecting 3v on pin 5 it works on battery despite having the indication as the power supply was connected.
    SIO have 3.3 all the time. power button 3,3v and ok.
    any help please.
    thanks Rui.
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    Re: Lenovo ideapad 310-15abr CG516 NMA741 only power on with power supply connected,
    Good Morning.
    I did some more tests.
    replaces bq24780 but symptoms remained.
    BATT+, B+ voltages are ok, transistor PQ503 is switching correctly and charges the battery, battery has respectively G/S/D 13.6v/7.6v/7.6v, with power supply has 7.9v/7.9v/19v
    PU601 and PU602 have voltages +3VLP and +5VLP both on battery and with the power supply connected.
    On battery, when pressing the power button, the voltages +3VALW and +5VALW appear momentarily and the fan turns on (about 1 to 2 seconds)
    If I inject 3V on the BATT_TEMP line, it connects with the battery, but in the operating system it appears as having the battery disconnected.
    If I inject 3V in the ACOK line, it connects with the battery, and everything works normally, but it prematurely discharges the battery even when it is turned off, besides having the charge LED always on.
    thank you.
    Rui
      03-31-2024, 02:12 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      07-01-2024, 06:34 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • madan1
      555 based power supply getting too hot
      by madan1
      Good day.
      I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
      The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
      After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
      When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
      06-23-2025, 04:38 PM
