iPad 8th gen "not charging"
  • HooF
    • Nov 2012
    • 20
    This week alone I have seen four 8th gen units in for not charging. Passes dock and tristar tests. Boots up with battery.
    Before I start swapping chips around I want to know if anyone has seen this? Don't want to waste time reballing a PMIC for nothing.
  • mon2
    • 14684
    Re: iPad 8th gen "not charging"
    Have you tested with other known good cables?
    Do you see the charging ICON upon docking of the cable to a power source / charger on any of the units ?
    Is this after some update?
    • GeirAndersen
      iPad .pcb file collection
      by GeirAndersen
      I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
      Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
      IPAD COLLECTION 1
      +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
      +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
      +---iPad mini3 820-00008(A1599) 820-00002(A1600)
      +---iPad mini4 820-00180(A1538) 820-00177(A1550)
      +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
      +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
      12-09-2024, 09:28 AM
    • badboyzzz
      A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
      by badboyzzz
      I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
      12-28-2024, 02:11 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • waterchill
      Apple iPad Pro 12,9" 4Gen no charging, but working fine
      by waterchill
      Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
      So I started to replace this parts:
      - replaced usb-c port -> no result
      - replaced battery -> no result
      - replaced usb-c chip CD3217B12A -> no result
      - replaced 343S00326 -> no result
      - replaced 343S00327 -> no result
      - replaced 343S00328 -> no result
      I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
      04-30-2024, 05:37 AM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
