HP g6-2238SL WiFi issue
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    As the title reads, I have a HP Pavilion g6-2238SL with the following info and issues:
    - motherboard: DA0R33MB6F1 aka Quanta R33 Rev F, HP P/N 680569-501
    - current WiFi card: Intel Centrino Wireless-N 1030 (BIOS does not restrict WiFi cards, apparently
    - CPU: Core i3-2330M (originally had a Pentium B960)
    - HDD: Hitachi Z7K500 500GB SATA3
    - ODD: Pioneer DVD-RW
    - RAM: 2x4GB DDR3-1333, Nanya + ASint
    Issue: Laptop will boot into Windows, but Wi-Fi led remains amber until it's put into Sleep mode. WiFi card is detected but shown as turned off and is unable to turn it on. Once it's resumed from sleep, Wi-Fi LED turns white and Windows shows all Wi-Fi points to connect to. Restarting does not help as LED remains amber, unless laptop has been put to Sleep at least ONCE after it has been cold booted.
    When did the issue happen: after updating BIOS to F.27 Rev A from HP site. WLAN did switch correctly with older BIOS (F.14 I think, not sure but it was much older than the one I installed.) and worked as intended.
    What have I tried:
    - various WLAN cards (surprisingly BIOS never checked for whitelist which resulted in being able to use any card) including the one that was listed under the battery (Ralink RT5390) to no avail - all do the same thing as the Intel Centrino 1030
    - various clean installed HDDs with three different Windows (7 Ultimate, 8.1 Pro and 10 Enterprise LTSC), all do the same thing - cold boot will not activate WLAN, putting Windows to Sleep/Hibernate will.
    - two different sticks of RAM of same size (Micron + Hynix) with no difference whatsoever
    What I have not tried
    - cleaning the ME region - I don't know how to do this and would appreciate if someone can help me do it without externally programming it (I don't have a programmer at the moment and cannot afford one currently.) as I figure it may solve the issue.
    - replacing the motherboard altogether - this would be a last resort,replacing it with the AMD counterpart (APU + 7670M)
    I am open to suggestions.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: HP g6-2238SL WiFi issue
    Usually incompatibility between WiFi card and BIOS or Windows (Windows 10 may especially cause issues).
    As a workaround you can tape the rfkill pin of the WiFi card miniPCIe connector.
    I would highly recommend against replacing with AMD motherboard especially with AMD dGPU. Much less reliable, draws more power so lower battery life and more heat. May not solve the issue anyway if you don't have a compatible WiFi card.
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      But... would an HP OEM'd Ralink card not work on it, despite being listed on the battery compartiment? I have tried a Ralink RT5390 card from a HP and nada.
      As for the AMD mobo, do APUs draw that much power? It's based on the Trinity arhitecture.
      EDIT: Tried taping RFKILL pin, same issue as before.
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        What if you disconnect the internal keyboard??(It has wifi switch, so worth probing)
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          Removed the keyboard, same issue. The only difference is that after coming from Sleep I have to manually open WiFi.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            Coming back to this as I have a CH341A programmer now.
            Would reflashing the BIOS + EC fix this? I can search up the correct BIOS for it (Intel + 7670M 1GB, not 2GB) but I'd like to know if this would solve my issues before going ahead and reflashing things.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • ResetReality
              Toshiba/Vestel 58UL2B63DB Wifi Issue???
              by ResetReality
              Hello fellow tech heads.
              Had this tv come in...issue stated reboots on wifi.
              Indeed it does. However, with wifi off or using cat 5 cable no reboot issues.
              So far ive changed mainboard and wifi module...also reset tv back to factory via service menu (4725)
              Still same issue... i do have a psu to swap but cant see it being that really as works flawless if wifi is disabled
              I thought fireware? But why only on wifi?
              Is it an issue with the memory cache filling up and having to reboot for more ram??
              At a total...
              07-04-2024, 12:28 PM
            • yuviuv46
              Help with audio,wifi and battery issue for 3420
              by yuviuv46
              Dell inspiron 3420 came in for service
              When i switched from ata to ahci the bios bricked and power on no display issue was there.I successfully managed to flash bios with external programmer now the display is ok when i upgraded from 7 to windows 10 os.it gets locked automatically.When i remove the battery the issue is gone btw the battery is in pluged in not charging no wifi sound working up.I have installed all the compatible drivers still no success any help would be great!!!
              10-24-2022, 04:49 AM
            • survivalbloke
              Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
              by survivalbloke
              This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
              03-20-2025, 02:29 PM
            • AlexVG
              Replacing the WiFi module on a vacuum cleaner iROBOT i7
              by AlexVG
              I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
              I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
              (This board does not respond, only the LEDs light up in a circle.
              The liquid damage is catastrophic and restoration is impractical).
              (I bought this board to get the WiFi module and camera).
              The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
              If...
              10-22-2024, 07:20 AM
              Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) Studio Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over...
              09-07-2024, 04:10 AM
