Lenovo NM-C111 REV 1.0 no AC_OK signal no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have a BOARD FS440FS541 NM-C111 REV 1.0 2019-01-08
    It has no power
    Ive check all coils no shorted coils
    I already change the CHARGER IC ( BQBQ24780S )
    Pins
    ACDET - 2V
    CMPOUT - 5.4V
    REGN -6V
    BTST - 5.6V
    VCC -19V
  • mon2
    • Dec 2019
    • 14618
    Re: Lenovo no AC_OK signal no power
    1) Link or post schematic if available.
    2) ACDET is too low. Only if ACDET is > +2v4 will the ACOK go high. Post the current voltage reading for ACOK pin.
    3) Next, power down and inspect the resistor voltage divider on that should be +19v on the HIGH resistor. Are the 2 resistor values similar in resistance like the attached ? The TI website has the full datasheet for this component.
    Post your updates.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Are you getting +19V on pin5-8 of 1st dc in mosfet?? Gate voltage for same mosfet on pin4??
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        PQ311
        pin 5 -20v
        pin1,2,3 - 0v
        pin 4 - 0v
        AC_OK has 0v
        PR302 has correct value and also the PR310
        I test the voltage of the pr302 and PR310 it has 0v value
        Ive chech the ACDET 2 resistor the (PR313,PR315) has correct value tested the PR313 pin 1 has 20v, pin 2 has 2.8v
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          PQ311
          pin 5 -20v
          pin1,2,3 - 0v
          pin 4 - 0v
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            Post your updates.
            What do I need to test next sir?
            • mon2
              • Dec 2019
              • 14618
              Re: Lenovo NM-C111 REV 1.0 no AC_OK signal no power
              (PR313) pin 2 has 2.8v
              This is a good voltage for ACDET.
              Q1: What is the voltage on ACOK pin # 5 of PU301 ?
              If ACOK is 0volts, confirm that the pull-up resistor @ RE42 is still present. Post the voltage reading on pin 1 and 2 of RE42 resistor (100k). This resistor is required as the ACOK pin is an open-drain style. This means there is a logic low support for ACOK but NO LOGIC HIGH. The resistor @ RE42 is used to soft-pull up the line to the +3v3 rail for the logic '1' state. Open drain = pin becomes OPEN when it is a 'high' state. Again, a pull-up resistor must be applied on this ACOK line.
              Does RE42, pin #1 read @ +3v3 @ +3VL ?
              +3VL is vital to the proper operation of this logic board so confirm it is there.
              Also confirm that resistor RE74 (0 ohms) is present.
              All this then must lead to the EC chip under ACIN# label.
              Next, power down, remove all power. Meter in resistance mode (200 ohms).
              Check & post the meter readings for:
              a) PQ311 - source (1-2-3) & drain (5-6-7-8)
              b) PQ311 - source (1-2-3) & gate (4)
              c) PQ311 - gate (4) & drain (5-6-7-8)
              then move to inspect PQ312
              d) PQ312 - source (1-2-3) & drain (5-6-7-8)
              e) PQ312 - source (1-2-3) & gate (4)
              f) PQ312 - gate (4) & drain (5-6-7-8)
              Confirm PU3501 (pin #5) is creating the +3VLP rail. Post the voltage reading.
              This +3VLP rail is then used as +3VL after the jumper (solder short) @ PJ3505. Confirm that the +3VL rail is correct at this short jumper short.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                RE42 pin #1 - 0v
                QE2 pin #1 - 0v
                pin #2 - 0v
                pin #3 - 0v
                RE42 9 kioOhms outboard
                a) PQ311 - source (1-2-3) & drain (5-6-7-8) -60Kohms
                b) PQ311 - source (1-2-3) & gate (4) ----6 ohms
                c) PQ311 - gate (4) & drain (5-6-7-8)----400kiloohms
                d) PQ312 - source (1-2-3) & drain (5-6-7-8)----2ohms
                e) PQ312 - source (1-2-3) & gate (4)-------2ohms
                f) PQ312 - gate (4) & drain (5-6-7-8)--------4ohms
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  PU3501- PIN 5 has 0V
                  PJ3503 - 0v
                  • mon2
                    • Dec 2019
                    • 14618
                    1) On coil PL3501, what is the voltage on pin # 2 ?
                    2) PR314, pin #1 ? This is the voltage that is required to power the charger IC so that it can function to deliver the V20B+ rail.
                    3) Be sure that the charger IC has been soldered properly in the rework.
                    4) Appears that mosfet PQ312 may be defective but first confirm that the IC is soldered OK and is being powered through PD302 (dual common cathode diode). Pin 28 of PU301 must be a valid power rail to function.
                    Once PU301 is confirmed to be powered, post the voltages on pins 3 & 4 of PU301.
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      PL3501 pin 1 has 0v
                      PR314 19.74V
                      Charger is soldered properly
                      PU301
                      pin 3 --- 0v
                      pin 4 ---- 0v
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        PQ312 is clearly shorted. Replace it.
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          After cahnging it sir the Board has power but its consuming around 50miliamps
                          without pressing the power on , blinking light power led
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            Pu301 -
                            pin 3 -19.95v
                            pin4-25v
                            pl3501
                            -stable 3.3v
                            pl3502
                            -stable 5.1v
                            • mon2
                              • Dec 2019
                              • 14618
                              What is the voltage of the ACOK pin on PU301 now?
                              Is every power rail normal now on the logic board?
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                all power rails is normal
                                PU301 Pin 5 has 3.2v
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  +3VL_EC present
                                  PLT_RST# 3.3v
                                  SYS_PWROK_EC 3.2v
                                  +1.8VALW present
                                  JCMOS1 3.1v
                                  • mon2
                                    • Dec 2019
                                    • 14618
                                    So it is working properly now?
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      No sir its only taking 50milliamps. And the power led is blinking. I know its not normal it should be around 100 or 200
                                      • mon2
                                        • Dec 2019
                                        • 14618
                                        You may have to reflash the bios but personally do not have experience with this. If you have the tools, desolder and back up the current bios contents.
                                        Then consider to erase and flash a fresh image to test again. Or wait on advice from others but often this is the next suggested step.
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • questore
                                          Lenovo Legion 5 missing EC_ON_5V signal (5v_AWL)
                                          by questore
                                          Dear all.
                                          I have a Lenovo Legion 5 that come to me as faulty.
                                          The problem was that Adapter_ID pin was shorted by some liquid... killing the EC (there was a hole in the EC) (therefore 3.3v was shorted)
                                          I have removed shorted EC it and tested that if i short EC_SBM_CK1 to ground, then the BQ24780SRUYR power IC lets 20v pass the first and second mosfet.
                                          Nothing else seems shorted when checking 3V,5V, 1.1V, battery or 1.0v coils, so I have ordered the new EC chip.
                                          I have ordered a preprogrammed Chip for NM-C921 and soldered it on. (No pins shorted after checking...
                                          02-23-2025, 04:25 AM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
