Dell E6440 shortcircuit
Re: Dell E6440 shortcircuit
1) Leave PL701 lifted.
2) Test for shorts on mosfets PQ704 & PQ705.
3) Suspecting that your short is from the attached region of the logic board. Inspect each component.
For the caps, you could quickly remove each and then check if the short is gone or not and then focus on the mosfets.Last edited by mon2; 09-05-2021, 08:39 AM.Comment
Yes. If short is still there, remove PQ704 & PQ705 and check again if it is fixed. Do not power up. Only check for shorts.
Have to leave for an hour or so...will check back later. If short is removed, attach the coil and check again.Comment
Perhaps it will be faster to try with a bench PSU, inject 1W and see which one gets warm?Comment
Ok back...you can try that method but should be rather quick to remove the 2 mosfets. See if that resolves the short. If the short is fixed - suggest to replace BOTH mosfets.
If not, then it is all about the local caps.Comment
Ok, i found the "guilty".
PC713 is short
Should i replace it or it work without it too?Last edited by Andreasbest; 09-05-2021, 10:24 AM.Comment
1) With PL701 lifted, you are only working with the dual mosfets and the local caps on the same rail.
Update - remove / lift one leg of PL700 as well - confirm the short is still there.
2) Before you start this next stage of testing - check on the resistance to ground for pin # 4 of the mosfet(s) = connects to pin 18 of the charger IC.
3) If you wish to inject a voltage - inject 1V and being a short to ground (or close to) - the part should heat up quickly since it was forcing the power adapter to shut off immediately.
At 1V - it should be safe enough.
You can dab each of the mosfets and local caps with alcohol and check which area evaporates the fastest - unless you have a thermal camera.Last edited by mon2; 09-05-2021, 10:28 AM.Comment
Excellent !
The solder back the lifted part. The laptop should be fine without this part. If you have spares, apply a replacement but will not be a 'show stopper'.
Be sure to consider a similar or higher voltage rated part - to be safe. It is a jelly bean part and quite common on other logic boards.
0805 non-polarized capacitor @ 22uf (can be a higher capacitance as well) but 25v or higher is recommended.Comment
Ok, MB is working fine. I will try to find another same cap to replace it, if no i'll leave it this way.
I'll follow the exact steps on the second E6440 and i'll return with news, thank you for coming so far with me and helped me : ))Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by manol278Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
[Mod. Edit]
Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...01-26-2024, 11:50 AM -
by gambitxphelp what mosfet can i replace this charging mosfet 6520 the brand of laptop is dell inspiron 14 3000...
by aaronkatriniHi all,
I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
- Put the card in my testing motherboard and start running Heaven benchmark
- Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
- Try to start it again and I get a slight move from the PSU fan - a clear short
- A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
- Put the... -
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM - Loading...
