HP 8440p Blank Screen
  • andresi
    • Nov 2020
    • 153
    • INDONESIA
    with eksternal monitor is normal, LCD good, Flexible good. 19v good, LCDVDD no V. anyone can help me?
    i cek in pin 29 nothing volt. its LCDVDD the problem so the lcd blank?
    Help
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Chrissygizmo
    Panasonic TX-48CX350B backlights but white screen , blank screen
    by Chrissygizmo
    Hi all, I’ve got a problem I hope someone can help me fixi.
    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
    01-11-2025, 03:18 PM
  • dicky96
    HP Elitebook Screen blank - backlights but no image
    by dicky96
    Hi guys
    I'm trying to fix this laptop screen
    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
    OK so I have the original screen which works but has lines across the bottom quarter of the screen
    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
    04-28-2021, 07:30 AM
  • dicky96
    HP Elitebook 8440P - Blank Screen, Caps lock and Number lock flashing
    by dicky96
    Hi guys this laptop has a bit of a history. Someone else has tried to repair it. When it came to me it was partially dismantled and has a new screen fitted
    The owner says it worked for a while after the screen was fitted, then the screen started to go 'funny' but I didn''t really get to the bottom of what they mean. They said it works with an external monitor
    What I found is, the screen is blank, it has backlight but no image and after a little while the backlight goes off. I don't get an image on an external monitor.
    All the leds are lit up and I cant...
    01-07-2021, 07:04 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
