A1466 Missing Vcore
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    A1466 Missing Vcore
    Logic Board:820-00165A
    It turns on without display. Vcore is missing. Rest all voltage are there.
    01.All_Sys_PwrGood-3.3V
    02.P1V8S3_PGood-3.3V
    03.P1V05S0_Pgood-3.3V
    04.DDRREG_PGood-3.3V
    05.P5VS4RS3_PGood-3.3V
    06.S5_PGood-3.3V
    Missing
    01.CPU_VCCST_Pwrgd. R1931 Pin1 has P1V05S, pin2 is zero.Resistance on R1931,pin1 is 110 Ohms,PIn2 is 0.885K.
    02.U7200,PIn1 VR_EN is missing. CPU_VR_Ready is present on R1955. Resistance Value of R1800 is good.
    R1931 showed incorrect value and was rusted/frozen on CPU_VCCST_PGood side. I've restored the two pads and soldered 10K Resistor. MB doesnt turn on if R1931 is soldered. If i remove R1931,it turns on without Vcore.
    Can U1930 be bad or i'm on wrong path??
    U1930 measurements
    PIn1-PM_SLP_S3_L-3.3V
    Pin2-All_SYS_PGood-3.3V
    Pin4-CPU_VCCST_PG-0V
    Pin6-PP3V_S5-3.3V
    Have'nt done anything apart from measuring rails/voltages and replacing R1931 .
    Please advise how to move further. As said earlier, i dont have much knowledge on macbooks repair
  • Askic
    • Sep 2018
    • 187
    • BIH
    Re: A1466 Missing Vcore
    Hello mcplslg123,
    please measure:
    P3V3S0_EN and check whether you have 3v3_S0.
    U8030 is a switch that transfer 3v3 _S5 to 3V3_S0.
    When P3V3S0_EN is 3.3V, it will "move" 3V3_S5 to 3V3_S0
    • piernov
      • Jan 2016
      • 4435
      • France
      PM_SLP_S5_L most likely pulsing with R1931 soldered. Check with oscilloscope.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by Askic
        Hello mcplslg123,
        please measure:
        P3V3S0_EN & P3V3S0-Both are present with R1931 unsoldered.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          With R1931 soldered, there is nothing on PM_SLP_S5_L. Consumption on dc Supply starts with 0.0015amps and goes to 0.0026A. magsafe light goes from green to orange. With R1931 unsoldered, PM_SLP_S5_L is stable 3.3V. With R1931 unsoldered it turns on, consumption at 0.0150A with missing CPU_VCCST_PGOOD
          • piernov
            • Jan 2016
            • 4435
            • France
            Set trigger to single shot rising edge at like 1V on the oscilloscope if you can't see the pulse right away.
            (maybe 500us/div horizontal)
            • lamo
              • Nov 2017
              • 38
              • Ukraine
              check these lines: svid_clk, svid_data and vid_alert. you should have some impulses at svid_data on CPU pwm ic.
              • piernov
                • Jan 2016
                • 4435
                • France
                Unrelated. SVID won't work if VCCST_PGOOD is missing.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  @piernov, will check it. Btw, if it pulses what is the solution??
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    https://logi.wiki/index.php/User:Pie....2C_what_do.3F
