Hp 15 IC identification help
  • Wrightyzere
    • Aug 2021
    • 5
    • Uk
    Hi can anybody point me in the right direction of a replacement for this ic 8a 3m 11e? Can't find any schematics or data To support it? It's from a hp 15 ba005na (mb bdl51 LA-D711P)
  • age80
    • Jun 2013
    • 55
    • Greece
    Re: Hp 15 IC identification help
    maybe a RT8243AZQW
    • Wrightyzere
      • Aug 2021
      • 5
      • Uk
      Originally posted by age80
      maybe a RT8243AZQW
      I will ask about and hopefully your right lol. I can't seem to work it out 😖
      • age80
        • Jun 2013
        • 55
        • Greece
        I'm sure SMDFlea or someone else will tell you for sure...
        • mon2
          • Dec 2019
          • 14663
          Originally Posted by age80
          maybe a RT8243AZQW
          Agree with the discovery.
          https://www.aliexpress.com/item/3286...5b9f069fba95-1
          • Wrightyzere
            • Aug 2021
            • 5
            • Uk
            top banana appreciated guys thanks a milllion, fingers crossed its a problem solved.
            • Shulgin
              Acer predator XB241YU Component identification
              by Shulgin
              I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
              After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
              In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
              I...
              05-11-2024, 11:06 AM
            • thebomb602
              ASUS GA402R IC identification
              by thebomb602
              Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
              also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
              EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
              11-21-2023, 02:30 PM
            • Tend0
              hp elitebook 840 G4 no 5v IC identification
              by Tend0
              Hello everythone
              i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
              i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
              05-31-2025, 09:13 PM
            • Tomylee
              Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
              by Tomylee
              I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
              It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
              I'm looking for help with the following:
              The exact identification or part number of the T5 component
              05-28-2025, 12:42 PM
            • FrozenHaxor
              SOT23 component identification
              by FrozenHaxor
              Hello, I have two identical circuits and one has a component with a hole in it, it is some sort of MOSFET driver, as two gates of large MOSFETs are connected to the lower right pin of it, I'd rather avoid guesswork if positive identification is possible.
              04-09-2025, 03:17 AM
